-   Scarab (https://www.offshoreonly.com/forums/scarab-41/)
-   -   Is this normal ? (https://www.offshoreonly.com/forums/scarab/137438-normal.html)
Strip Poker 388 08-17-2006 12:35 PM
Re: Is this normal ?
Originally Posted by 2 Trick Rick
Mine
Thats looks about right.
Ill take some picks of mine just to see.
Frankscarab 08-18-2006 01:04 PM
Mine
Thanks Rick
Seem like mine
Frank
Strip Poker 388 08-28-2006 10:52 PM
2 Attachment(s)
up and down
tssteph 08-29-2006 02:03 PM
1 Attachment(s)
ok, here is a pic of my 29 with 280's on it, as you can see they are completely retracted.
tssteph 08-29-2006 02:05 PM
1 Attachment(s)
In this pic from straight on from the back you can actually see the bottom of the tab, thats the reflection that you can see.
tssteph 08-29-2006 02:06 PM
1 Attachment(s)
Last one, you can see how far up they go when up.
trc2 03-17-2007 12:24 PM
Originally Posted by Frankscarab (Post 1826353)
I everone , i need to know if my trim tab measurement (inch travel ) are good or not.
There is a pic of my both trim tab at the higher position , like you can see i can't put in all the tab , i've still have 3 inch of travel between the tab and the cylinder.
Is it normal ?
Dont know if you fixed the problem yet but I have a 2000 29 scarab and my k planes had a spacer in them to keep the tab from going all the way up to keep the boat stayble
scarabman 03-18-2007 02:31 PM
Exactly!!! Remove them and you can bring the tabs further up and free up the bottom with less positive drive trim.
