Proper trim adjuestments
Bought my 2000 Scarab Sport a few months ago and have almost everything set up. Noticed two problems when operating. First, the sterring has play. Posted a separate thread to address that.
Second, It tends to be pretty loss when operating at mid-range speeds. Even when you compensate quickly for the play in steering, it wanders quite a bit. Of course, when you adjust the engine trim, it changes it's ride, doesn't necessarily clean up the wandering. Should I be using some bow planes for downward resistance, then use more engine trim? Open to your comments. Thanks, Jon |
my dad had the same problem, his was a leaking steering line so i bet it's in your hydrol. steering, his is rock solid now.
Sounds like a steering issue that is turning into a safety issue. Have it checked out real good. Hope it's not expensive.
| All times are GMT -5. The time now is 08:04 PM. |
