-   Scarab (https://www.offshoreonly.com/forums/scarab-41/)
-   -   Scarab part help (https://www.offshoreonly.com/forums/scarab/189470-scarab-part-help.html)
djones 06-23-2008 09:06 AM
Scarab part help
Need some help. I have a ’96 26’ Scarab & a nasty storm claimed my rear port side vent cover. The factory was no help & told me that the cover would have to be custom built by someone & they no longer had the forms to make it with. Anyone here run into this before? Even though the vent cover is just a piece of molded plastic, I want to keep the stock look. Is there anywhere that has these as aftermarket or old stock?
kyoung 06-23-2008 10:32 PM
I've been looking also. Same 96 Scarab, side vents are starting to crack near the screw holes. No luck finding them anywhere either, was going to have brother in law (works at a body shop)look to see if they can be repaired. I know that doesn't help you though.
Good luck!
djones 06-24-2008 09:24 AM
Have spent hours on the phone to many suppliers on the vent covers. Received what I believe to be the correct part numbers from Wellcraft - 68464005 Vent Port Side & 68464013 Vent Stbd Side, but still did me no good. I had come to the conclusion I’m going to have to have these manufactured. Open to any suggestions.......
bri460 06-24-2008 10:53 AM
i looked for a long time for my 78 scarab ended up finding one on ebay. whats the aprox. size of it
djones 06-24-2008 12:43 PM
Approx 3 ½’ long & 1’ wide – scalloped & kinda resembles a tucked bird wing.
Kims 06-24-2008 08:19 PM
Look at www.livorsi.com then call Mike or Fred, I am sure they will be able to help you.
502ss 06-25-2008 04:49 AM
How much are you looking to spend? If you really want to reproduce the same as whats already on the boat, I can bang the design out for you with my 3D CAD software. You can then take the 3D CAD model to a local machine shop that has CNC capability and have them cut it out of any material you want, you could also upload the 3D CAD model to www.emachineshop.com and they will cut it for you also. The cutting may be expensive because of the setup time for one part.
IMO, this may be a good time to change the look and buy new vents from someone like www.eddiemarine.com, ww.danamarineproducts.com, www.livorsi.com, etc.
:D
djones 06-27-2008 07:47 AM
Contacted Livorsi & they forewarded a request to a fabricator they use. Will update when I find out more info. Thankx for the contact.
daveboys 07-01-2008 03:13 PM
I would be interested in a pair you you get some one to cut them.
djones 07-01-2008 04:06 PM
Livorsi's fabricator couldn't do it. Still looking......
