Looking for Scarab help
Hi I am looking for some help with my Scarab
33 AVS. I cant get a response from Welcraft I am looking for help with the x dim. If I can get pointed in the right direction it would be a big help thanks |
Scarab105,
The shop that does all my work is putting extension boxes on a 33AVS. It also has 502mpi's with Whipples on it.He does great work and is real knowledgable. I think the 33 is running in the 90's!!! Go Scarab!! Give him a call Lil' Bill Select Boats 713-910-2000 Tell him Shawn with the 29 told you to call!!! Good luck!!:D :D |
what is the problem? What are you trying to do
I am looking for anyone who can tell me what kind of results I
will get with 2 inch shorter drives and or standoff boxes. Right now the boat is apart and I am getting ready for ice out My speed now on the radar gun is 103 mph |
scarab105,,
What kind of engines are you running? Sounds like you have some serious HORSES under the hatch!!! And you know how we like HORSES!! :D |
Somebody posted this way of measuring X-dim. on this board awhile back.
This is for Bravo's. Measure at the transom from the keel of the hull to the bottom of the outer drive mounting plate. Add 9.25 inches to this measurement. This puts you at the driveshaft height/X-dim. |
29scarab,
Thanks for the lead Lil' Bill said they run the Imco
1 inch shortie and picked up 4-5 mph. so some gains can be had. Now we need to find someone that has tried to 2 inch shorter unit. by the way it is 850 hp |
What about a sacrifice in handling with the shorties. Should that be considered? or are you already passed that?
I am not sure what will happen to the handling
with the shorter units. Right now handling is still good The boat is solid in the water. I think this is a question that needs to be answered. I could put standoff boxes on if it is a problem. |
| All times are GMT -5. The time now is 04:06 PM. |
