-   Scarab (https://www.offshoreonly.com/forums/scarab-41/)
-   -   MPH out of a 22'? (https://www.offshoreonly.com/forums/scarab/203413-mph-out-22-a.html)
maryokaan 06-15-2009 05:13 PM
210 liters i believe...
this boat should go faster somehow but cant guess where to start making modifications....
maryokaan 06-15-2009 05:15 PM
Originally Posted by Rookie (Post 2888377)
Do a search in the Performance Technical section. "330 on Roids"
hi & thanks
which section is that ?? can you send me a link?
Rookie 06-15-2009 06:27 PM
Originally Posted by maryokaan (Post 2888826)
hi & thanks
You ask and you'll receive.
http://www.offshoreonly.com/forums/g...-steroids.html
http://www.offshoreonly.com/forums/g...30s-roids.html
http://www.offshoreonly.com/forums/g...l-results.html
Mopwr 06-15-2009 07:51 PM
Scarab
Thanks for the info on the fuel capacity ....I think it can go faster then that as well ......have mixed messages to thru hull...some say you gain horse power ...some say it is only for sound !
Rookie 06-15-2009 09:20 PM
With exhaust you do gain HP if it is there, but it is not usually significant enough if that is the only thing you change. Usually the stock exhaust will support stock HP. If you start adding modifications that make your engine breath better then you will need get a better exhaust. You need approximately 15-20HP/ 1mph net gain in speed. (all hulls vary)
Mopwr 06-16-2009 07:18 AM
Scarab
Thanks for the help on the thru hull ......I think thats were I will start ......
