-   Scarab (https://www.offshoreonly.com/forums/scarab-41/)
-   -   29 scarab//350mpi's (https://www.offshoreonly.com/forums/scarab/223128-29-scarab-350mpis.html)
humpster 01-20-2010 07:07 PM
29 scarab//350mpi's
dart claims to have a set of heads that will gain about 60hp match it up with the right cam will gain 100hp on my small blocks trouble is no one knows of a program for the ecm to go with the new combo does anyone know someone that can redue the computer to make this work
29scarab 01-21-2010 06:58 AM
There are quite a few places that can do it. If you look under marine links here on OSO there are some. They are located under engine builders, or general. My engine builder used someone in Louisiana that new there stuff.
Good Luck!!
humpster 01-21-2010 11:23 AM
problem i've heard is lots of programs for big block stuff not for small block unless you spend lots of dyno time to get it perfect. big blocks 100's of proven programs written so no dyno time required is this true?
trc2 01-21-2010 02:36 PM
The only right way is to put them on a dyno and tune them that way So you are probley looking at spending close to 1000 dollars to do that
Jeff P31 01-21-2010 07:23 PM
Running them on a dyno will be the best money you spend. Know guess work just the faxs , tune it on the dyno and bolt it in the boat and go boating . Or spend the next 6 months standing on your head trying to find the right tune up in the boat. I have tried it both way's and I will never put an engine in a boat with out first running it on a dyno. Just my .02 Jeff
humpster 01-21-2010 09:45 PM
thanks for the input
scarabsc 01-25-2010 10:32 PM
The name of the shop referred to in Louisiana is precieion marine in the New Orleans area
berryo 02-03-2010 05:44 PM
I think the Lagrange educated man means Precision Marine
