-   Scarab (https://www.offshoreonly.com/forums/scarab-41/)
-   -   Scarab 22 Trim tabs/stability (https://www.offshoreonly.com/forums/scarab/231202-scarab-22-trim-tabs-stability.html)
larose481 05-24-2010 12:31 PM
I have done searches with minimal results so was wondering if anyone has played around with different trim tabs on a scarab 22? Right now I am running in the 79-80mph range and the boat is very unstable at wot. Still have the stock steering but just replaced the helm, rack and cable with the latest Teleflex Extreme system and haven't tried it yet hopefully this weekend. I was talking with a guy from Wellcraft that helped design the 22 and saying hydraulic steering is not manditory as the problem is the spray from the nose is spraying past (outside) the back of the boat causing the loss of support to the stern causing chine walk. So.. after this long ass story I was wondering if anyone has played with different trim tabs or has a stable Scarab 22 that runs in the low 80's and what is their combination is. Thanks.
fastscarab22 05-24-2010 06:59 PM
I have a set off electric tabs, and i really never use them but it makes the boat seam toride like a bigger boat and 1 foot on the stern makes a big differnce in big water . I am running about the same speed with hp 465 with some work and 1 inch shorty on it and drew marine side winders runs real stable at speed
larose481 05-26-2010 09:51 PM
No one else?
97scarab22 05-31-2010 08:59 PM
I have the Eddie Marine Sport tabs on my 22, makes the boat jump on plane with weight in the boat, makes the ride more stabil and helps the boat take on bigger water with ease.
overtime1 06-16-2010 09:35 PM
Trim Tabs
I have Lenco 12x12 Sport tabs on 97 scarab 22. Made A big difference in rough water and getting on step.
larose481 06-23-2010 09:45 PM
Thanks for the replies. I will be looking into some different tabs and see what happens. Any tabs that are better than others or does any particular brand have better customer service? Thanks again.
freshwaterfiend 07-12-2010 10:46 AM
What prop are you running? Modern props probably generate too much stern lift for your boat and it's riding too high at speed. Getting a prop with less lift will really help stability without really affecting top end. I've got the same problem on my SCS, it really likes to dance at the top end.
outriggers 07-12-2010 12:08 PM
I put K plane 110's on my 97 22'. I did it thinking it would come ot of the hole better. They looked great but I don't think I would do it again. I found that going to a 4 blade Bravo helped the most. I would want hydraulic steering. Doug
