Need help on 1996 Scarab 22 rebuild >
Old 06-17-2010 | 01:03 PM
Default Need help on 1996 Scarab 22 rebuild
We bought this boat new in 1995/1996
boat has the Carb 454 in it.
The boat sat up over 6 years with no cover.
My first question is does anyone sell carpet kits already got to size for the boat so its jut a peal out and replace procedure?
Next we are looking for new guages for the boat and a steering wheel.
The floor seems flimsy can we just put a new piece of wood down over that as a "lay in" for support for the summer til we can have it all rebuilt?
Any other upgrades to do on this boat being older
thanks
Ryan
97on22s is offline
Old 06-17-2010 | 01:07 PM
DollaBill's Avatar
OSO OG
Floor is prob rotted. I had the same boat. More of a problem could be the stringers. I actually had to get the hull replaced onmine. Reused the deck and power/drive. Dig a little deeper to make sure it's even safe to run
DollaBill is offline
Old 06-17-2010 | 01:12 PM
Will do. I have a tech coming by this afternoon to take a look around and see what his thoughts are.
I hate to dump a whole lot into this if in the end its still not going to be worth much of anything and i could just round up a newer boat.
97on22s is offline
Old 06-17-2010 | 01:43 PM
Gladhe8er's Avatar
I agree with Dolla. I had the same exact boat and you have to watch it when water gets on the carpet. Gotta dry it out ASAP to keep it from getting into the floor/stringers. I don't think you will find a carpet "kit" for that boat...you will need to have one made.
Mine had a custom dash/steering wheel with Livorsi guages. See pic below.
Gladhe8er is offline
Old 06-17-2010 | 08:56 PM
Ive got an question about replacing the carpet with spray in bedliner instead?
Can you do this do a bedliner spray instead of carpet? And where would the water drain if i did this?
97on22s is offline
