oil temp
Old 09-04-2010 | 09:33 AM
Default oil temp
29 scarab with twin 350 all stock when running 4000 rpm oil temp will rise to 250 that seems high to me anyone else temp that high. even at 3500 rpm temp is about 210-220
humpster is offline
Old 09-06-2010 | 07:46 AM
Find your oil coolers, pull the incoming water hose off the end, and stick your fingers in the end of the cooler and see if there is any rubber impeller pieces blocking it. Check both motors. This doesnt take very long, and is worth the piece of mind sir.
tinman565 is offline
Old 09-14-2010 | 11:53 AM
I have my temp sender in the oil pan and if I run 4k for about 10 mins, it will climb up to around 240. It does seem to level out there when running it hard for along time. I think where you mount the sender can have a difference on the temps also. I have seen people put it on the remote oil filter adapter, but i dont know how much difference it makes on reading temps.
Big Block is offline
Old 09-15-2010 | 05:57 PM
finally got back to look at the oil coolers and found out that there isn"t any on the stock 350 mpi"s so hopefully those temps are running in a safe range i'm running straight 30 weight and change it every 40 hours
humpster is offline
