Broke off block drain plug
My problems continue, I snapped off one of the blue plastic drain plugs. Any suggestions on how to get it out. Is it a pipe thread ??? I do not think a drill will fit down in there.
put a wrench on the brass housing it is threaded into & take out the assembly.. Then you can either work out the blue plug and just replace it or you can replace the whole little assembly. If you need replacements feel free to give me a shout..
Hope this helps..
Jamie / Lakeside Restorations
Hope this helps..
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
You might also try a left handed drill bit in a pair of small vice grips. This worked for me once. I like the external torx bit idea; I'll remember that one. That and an external hex bit might work too in a pinch.
