How am I loading my Scarab wrong >
Old 08-18-2011 | 08:26 PM
Default How am I loading my Scarab wrong
So I dont want to start a "power loading" thread but I need some help. I have the 22 Scarab and whenever I load on the trailer the bow ends up about 2-3 inches from the roller.
I get it all the way up against the roller, winch tight and when I get to the rigging lane it is like 2-3 inches away.
I did get it once but no idea how. I have tried pulling in farther, powering on and I need some sugestions.
pluguglyinhere is offline
Old 08-18-2011 | 09:10 PM
Well every boat is differnt but what I do is back my trailer till the fenders are just under the water, drive the boat on trailer up to the roller trim everything up get out the boat and winch it up till the bow hook touchs the roller...I have a 28ft powerquest...
boatrider82 is offline
Old 08-18-2011 | 09:53 PM
Downtown42's Avatar
Not sure if this will help, but unroll your steel cable ALL the way and rewind up TIGHT and even on the spool. They can get out of wack, and jump back when you're winding the boat up.
Downtown42 is offline
Old 08-18-2011 | 10:34 PM
Is it a steep launch ramp?
My 30" scarab has done that to me a couple times on a steep ramp, it is the angle of the keel when floating and then tips up when on the trailer leaving a gap on the bow roller.
I now winch a little further than it seems I should on the steeper ramps and it works out great
flyinlow is offline
Old 08-18-2011 | 10:50 PM
jeff32's Avatar
drive very slowly till the boat is completly out of water... should be fine... as good as the above suggestion...
jeff32 is offline
Old 08-19-2011 | 12:26 PM
I always winch it all the way up, then put on my front safety strap so I know it's not going anywhere. I've seen too many winch straps break...
-Rob
RivMan is offline
Old 08-19-2011 | 04:10 PM
First off I have a winch STRAP not a CABLE, should I change?
It is a steep ramp and that was one of my thoughts was as I pull out the boat sits back causing the boat to raise away from the stop so to speak.
I always hook the safety chain before pulling out of the water.
I dont know that I can winch it up further because I tighten the u-bolt up to the stop now.
Old 08-19-2011 | 10:30 PM
my bow eye is always above the bow stop
I have never had a boat that has the winch mounted too low to pull the eye above the stop and I prefer the straps over cables just make sure you have a heavy duty strap and it is in good condition
of course you need to pull it out of the water slowly also
flyinlow is offline
Old 08-20-2011 | 11:37 AM
jbraun2828's Avatar
put another strap going from the bow eye down to the trailer somewhere and it wont move
jbraun2828 is offline
Old 08-21-2011 | 06:31 AM
c_deezy's Avatar
Does your strap come off the winch on the bottom side or the top side?
Mine used to do something similar when I had the strap coming off the winch on the bottom. Unwound and re-wound it so that it comes off the top of the drum and it doesn't do it anymore.
c_deezy is offline
