1986 Scarab Panther
Length: 30' Engine: 2 x 469 Horsepower: 2 x 600 Outdrive: TRS Prop: 26 Spinelli 4 blades and 25 Mirage 3 blade Top Speed: 78+ still prop testing |
1991 scarab cv, length 26 , 502 , 1.36 gears , 21 mirage, 68.7 mph have not tweaked the prop yet going to talk to BBlades Mike
Length: 22
Engine: 454 LX MPI Horsepower: ??? I would love to learn how to tell which 454 I have and what the hp is. Outdrive: Bravo 1 Prop: 24P 4B Bravo SS Top Speed: ???? to new to my still havent had the GPS in it yet |
1998 38' Non- AVS
Length: 38 Engine: Merc 575SCi(w/superchillers 3 1/4" pulleys-7lb boost) Horsepower: 650x2 Outdrive: XR Prop: bravo 1 28 lab Top speed: 78 (ish) almost 80 bumping 5000 rpm |
1996 P-31 40th Anniversary
Length : 31 Engines : HP 500's with Pro Chargers 7 lbs. Horsepower : 750 x 2 Outdrive : XR upper & -1 Imco lower Prop : 32 P 4b & 34 P 4b for cruising Top speed : Never fast enough |
2000 26 Larry Smith
HP500/Bravo 1 30P Bravo 1, 5100 slightly over trimmed 78 to 82 MPH depending on conditions and load Unbelievably stable ride |
1995 38 Flat bottom
Length : 38 Engines : 583 BBC 10-71's with superchillers Horsepower : 900 x 2 Outdrive : SSM V with 2 " spacer Prop : 18X31X18 4 Blade Merc Racing Cleavers Top speed : 105 @ 5900rpm |
1995 29'
565/650 bravo1 outdrive/hd transom assembly New transom/2" up on the x-dimension 28 pitch b1 lab 78mph gps |
Originally Posted by Mad Mac
(Post 3508812)
1995 38 Flat bottom
Originally Posted by Shallow Minded
(Post 3510740)
Any pic's of your boat? Sounds bad-arse!
| All times are GMT -5. The time now is 08:23 AM. |
