Meteor 5000 with single turbine >
Old 11-05-2013 | 06:54 AM
Originally Posted by Jorekore
Hi.
I'm planning to put a 1400hp T58 turbine with arneson or speedmaster drive on a 50' scarab, the boat will wheight less than with triple BB and much less than with two big diesels, but will it work? Would the boat be controlable? Would it get up on plane if i use a 6blade prop?
It is the best choise for less money than other choises.
Even if that performed flawlessly, do you have any idea how terrible it would be around the docks? It would be a nightmare to get in a slip.
Plowtownmissile is offline
Old 11-05-2013 | 02:36 PM
I thought I recalled a guy years ago that had a single turbine in the middle, and then concocted a chain drive system to two transmissions and two Arneson surface drives. I don't recall how it worked out though. Maybe some research will turn up the boat.
CDShack is offline
