Mopar guy here .....
....how much trouble would it be to install 440 motors into a boat that has 454's in it? ...
i had 440 s in my 30 silverton flybridge boat really had some get up and go for a big girl tons of torque but she was an in board the bell housing is going to be the problem maybe some kind of Chevy to Chrysler adapter but i must say for as much as i liked those 440s i think the chevy is a better design and much more abundant parts are available
Yeah ...I hear you on parts avail etc ... I am just asking. There are bells out there .... is the Rat motor bell for a std type car trans that adapt to the outdrive?
i am not sure about ,say a trs setup that has a transmission but for bravo it is a specific bell housing that has 2 attaching points to the gimble housing as i was saying though you may be able to get an adaptor say from a company like trans adapt that will let you put the gm bell housing from merc on the 440
Have you heard of JW Transmission in FL ? ... they make these bells to adapt diff trans to diff motors. You think you could eyeball that ? ... I do have a chance to pickup a RUFF Scarab with no motors ....cheap ... NOT sure of the outdrives though ...
what year i think bravos came out in 87
i am sure some one else will chime is soon about why this can't be done but there are other things to think about like flywheel and coupler problems that would have to be figured out
Originally Posted by mach1magnum
(Post 3583090)
Plenty of bell housings out there for big block mopar to Borg Warner transmissions, prob all out of cruisers with straight inboards, no performance exhaust around for them, other than that no reason it won't work, but would be cheaper and easier to big block chevy's in. As far as flywheels you'd have to move the ring gear, on the mopar flywheel, and a regular trs flex plate should bolt up
there you go what he said
You would not be able to use a Bravo. I have never seen a Chrysler engine used in a Merc setup and the bellhousing is the rear engine mount so you have to have a Merc bellhousing or something custom fabricated. Frankly for all the trouble it just isn't worth it.
My question is why, seem like a lot of work for very little gain, most parts available bbc and cheaper, dont get me wrong I'm all for the custom thing, i build custom cars for a living, do a lot of motor swaps, in fact just did a motor swap in a 71 RT Charger from a 440 to a 540BBC:party-smiley-004:, now he can take the car to the Mopar nats, and Super Chevy...He gets bunch of flak but he loves it....so i say if you got money to through a the wall, and want the wow factor go for it.......:evilb:
Besides the initial cost and all of the custom fabrication. I see a real hard time selling it when the time comes.
My biggest question is why would you post this in the Scarab forum?? |
THX guyz ... I thought that this might be a minor PITA ... but it seems that it might be way-more than that. The reason why I am posting this here .. is that I do have a line on that ruff Scarab that needs motors. JUST trying to get some food-for-thought on this new "hobby" I would like to start.
| All times are GMT -5. The time now is 08:18 PM. |
