-   Scarab (https://www.offshoreonly.com/forums/scarab-41/)
-   -   29' w/ 350 mags... what props? (https://www.offshoreonly.com/forums/scarab/285032-29-w-350-mags-what-props.html)
HZ900 09-18-2012 01:39 PM
Have any of you guys experimented with different prop set ups? I've got the Bravo/350 mpi mag setup and was wondering what everyone was running and what top speed to expect.
Baldie 09-20-2012 12:51 PM
I have a 30 with 350's and TRS and I run 21p but it will run out to around 5200. I always wanted to step up to 23p and see what happens.
scarabman 09-20-2012 02:39 PM
Most guys I know are running Mirage Plus 23s on the 29.
when I had mine I went from 23s to labbed Mirage Plus 25s. It gained 1 to 2 mph, but truthfully was not worth it IMO.
HZ900 09-21-2012 12:54 PM
Just wondering what it takes to get to mid 70's, without tearing the motors apart.
supermx96 09-21-2012 08:22 PM
You will need more HP or put Blackhawk drive on them.
The p-29 with Blackhawk drive run 75mph i think.
tssteph 09-21-2012 08:59 PM
Pro chargers. Mine ran 80 every day.
scarabman 09-22-2012 05:42 AM
The P-29s run 75-77 but Blackhawks alone wouldnt do it. The P-29 is about 700 pounds lighter due to the Kevlar layup and it also has a slighlty different bottom configuration in that that are no wedges molded in between the outer lifting strake and the chine.
With some set-up tweaking you can get into the low 70s, after that you are going to need power to go further.
HZ900 10-26-2012 11:40 AM
So I looked at the pitch on mine (new boat to me in the spring) and was told that the props were original. What I found is that they are mirage 21s, 3 blade. What would going to a 25 4 blade do for me. I ask because someone I know might have some to sell me.
humpster 10-26-2012 12:34 PM
25 are way to much prop if it's top speed your after 23 mirage plus is it i put 22 4 blade on my 29 and lost 5mph on top end picked up crazy low end torque though with the 23 69.7 on gps
