-1 or -2 on 700hp 22' Scarab?
Anyone out there have a good setup they can recommend? What prop at what height?
Buy the -2 lower ... you can always run a spacer if needed ... much easier to sell if its an epic failure ! :)
700hp and a shortie on a 22 scarab. Can you please PM me your full name, date of birth, address and any other pertinent info so that I may take out a life insurance policy on you?? Other than that, sounds like a blast!!
Originally Posted by phragle
(Post 3937725)
My buddy just sold one with a mild 496 stoker making close to 500 and that thing would get pretty scary! |
I have zero respect for my own life. -2 it is.
Let us know what it runs, sounds like it would be fun _2 the way to go though
I run 600 hp on my 22 scarab at about 85. Standard lower on a bravo one X. Depends on the amount of fuel on how wild the ride. It's not for rookie operators. I can't imagine a -2 Inch
You guys are crazy! 75mph in my 22' can get alittle un stable at times!
Originally Posted by tmbl52
(Post 3963262)
D harry where is the propshaft in relation to the bottom of the hull. Scarab seemed to always burry the xdimension on single engine boats. A -2 should carry the boat much better than in stock location. what pitch prop are you using? what rpm is your engine spinning? if you can spin more rpm's and reduce the pitch it will allow less stern lift. i know 525 efi's have rev limiter's but boats that run big hp around here spin 6000 rpm range.plus it is easier on the drive.
Originally Posted by hullofjustis
(Post 3964098)
I would say yes if you do not like the stern lift and or the ride feels unsafe. you may loose a little speed and cruise may decrease but if you spin more rpms same thing can happen. i am not a big fan of 1.36's so unless you can have the rev limiter tuned or turned up 1.36's would be the way to go. if you have a -2 drive on your scarab and you are still 3 1/2 below the bottom that is still pretty low but much better then factory location. my panther is set up to be 1 1/4 below the bottom with a -2 and 3 1/4 with standard bravo. so at some point if the transom wood gets rotten you should raise the x dimension higher. i also forgot that the 22 has a pad. bravo ones props can make pad bottom boats a little squirly. hydromotive may be a prop to try but I did not like on my single engine 29 scarab.
(Post 3964872)
82@5200 rpms stock 30p bravo, 1.5 XR/-1 combo. Boat starts to bow steer pretty bad think I need a bit more bow lift.
Originally Posted by MINK
(Post 3963412)
Is the prop blowing out ? Is that all you can turn up RPM wise with that 30? John jr |
Boat is still accelerating but I haven't had the balls to push past 82 yet.
| All times are GMT -5. The time now is 12:31 PM. |
