-   Scarab (https://www.offshoreonly.com/forums/scarab-41/)
-   -   Scarab 29 engine hatch is stuck. (https://www.offshoreonly.com/forums/scarab/315962-scarab-29-engine-hatch-stuck.html)
Crowney 07-28-2014 07:57 AM
My engine hatch is stuck on my P29. Exact same setup as a 29 scarab. Any suggestions on how to get it open?
CDShack 07-28-2014 01:11 PM
If you have electric ram lifts, the hinge that attaches to the hatch is generally thru-bolted//threaded into the hatch bracket. You can unscrew the screws and lift it up.
Crowney 07-28-2014 06:12 PM
I will have to check. I thought all hardware was only accessible with the lid up but I hope I'm wrong. It got stuck after the batteries were turned on so wasn't a big deal all weekend. I appreciate the help
CDShack 07-28-2014 07:02 PM
If not, you can charge the battery through the cigarette lighter. You can get a cigarette lighter plug charger adapter at a lot of auto parts stores. I've seen guys to that, or go under the dash and find the heavy wires running main power up front and hook a battery onto the wires with jumper cables.
Crowney 07-28-2014 08:08 PM
I have the Buffalo Poker Run coming up August 8-9 and I want to change my fluids before running it hard that weekend. I will get into it, lol.
I appreciate your help. It just might get me out on the water one of these days if I can't get into it in for a quick cruise.
scarabman 07-29-2014 05:53 AM
Should just be able to manually lift the hatch? They had a pvc "slide sleeve"on them from the factory for just such a purpose, unless yours has been removed over time?
hullofjustis 07-29-2014 07:25 AM
the ram should have a plastic tube with a 1 foot channel cut into it allowing it to slide up and down manually if your batteries were to die. 3/4 inch nut and bolt may have been tighten to much to allow it to slide. oops just what scarabman said
CDShack 07-29-2014 05:32 PM
Hmmmm. Mine never had the sleeves, but the top brackets were through bolted.
Come to think of it, I have seen the PVC sleeves, wasn't 100% sure what they were for! Learn something new everyday.
indysupra 07-29-2014 08:22 PM
My 31 has the PVC sleeve.
Slinky 08-03-2014 02:39 PM
my 29 you can just manually lift it… heavy as hell but it should just lift up. your going to need some help
