scarab kv with speedmaster drives >
Old 02-16-2015 | 08:23 AM
crazy canuck's Avatar
Default scarab kv with speedmaster drives
I have a 88' 38 scarab kv (non notch) that i bought without power and drives .I purchased a set of ssm3's to use on the boat and my 600hp motors out of my 30 scarab II. My question is what x dimension (running surface to prop centerline) are these boats happy with ? I plan on using 12" ext boxes (still yet to purchase) with the ssm'3s .I have read a lot of posts on the x dimension subject but need to know what setup the guys with the kv"s and ssm's are running?Future plans for boat are ssm 3a's with bigger power . Any information would be greatly appreciated.
thanks mark
crazy canuck is offline
Old 02-16-2015 | 09:03 AM
On my Excalibur hawk, very similar bottom, 3" below the running surface with a 17" diameter prop works VERY well. That's a 21.311" x dimension. If your using boxes go up 1"
Unlimited jd is offline
Old 02-16-2015 | 05:12 PM
Team Archer's Avatar
I wouldn't go any higher than 21 1/4 because the weight of the bow you might have problems getting on plane if the boat were a Larry Smith Scarab then you can go higher the production boats were very heavy in the bow. That put your prop shaft 3 Inches down. I would start with 17.5 to 18 Dia props we have found that the big V bottoms like more Dia.
Team Archer is offline
Old 02-16-2015 | 05:37 PM
The boat has minimal cabin, padded bench seats carpeting thats all . No cabinets , fridge or sink . The 3 " is that with or without ext boxes ?
Mark
Old 02-16-2015 | 07:37 PM
Yes that's with ext. boxes The problem is Wellcraft used plywood for everything all bulkheads stringer benches and deck core that's what makes them heavy in the nose. We rigged a 2000 38 with number Vs and we had to be 3 inches below the bottom to get it on plane in under a minute. Wellcraft didn't know how to build a light boat.
Old 02-16-2015 | 08:20 PM
Thanks for the information guys , now i can get busy looking for 12" stellings ext boxes .
