X-dim for NXT/#6 drivefor stepped hull Scarab >
Old 06-27-2017 | 04:22 PM
Default X-dim for NXT/#6 drivefor stepped hull Scarab
Hi, would anyone of you owning a Scarab 33AVS/38AVS be able to help me out here. As you may know I'm putting NXT drives to mine and I need to deside X-dimension, -2" inch from bottom is what I'm thinking. Unfortunately I do not have any visibility on Scarab stepped hulls if some one has put on either #6 or NXT1 surface piercing drives on them? if you may have knowledge or good opinion how to set the correct X-dim on my boat I would die to hear about that, or if you have experience on setting up this type drive on stepped hull boat and you are capable of doing a educated guess on what the X-dim should be.
Any help would be much appreciated.
Thanks.
Roope
roope is offline
Old 06-29-2017 | 08:01 AM
hullofjustis's Avatar
Screen name team archer seems to be the most knowledgable when it comes to older scarabs so i would assume the same when it comes to newer scarabs
hullofjustis is offline
