suggestions on props for a 86 panther with 454 efi mags >
Old 11-27-2017 | 10:21 PM
Default suggestions on props for a 86 panther with 454 efi mags
I'm in the process of swappin in some proper big velvet drives from the worthless babies I had in it. Before I started tearing into it, I did have some transmission issues, but I was having a lot of blowout trying to get on plane. I was running a 4 blade prop on 385hp 454 efi mags. I will try and get the specs on the props tomorrow. Even with a bad trans I could probably hit 64mph gps. Not sure I never did gps at both wot at 5000rpm.
Anyhow, I'm looking for a suggestion on a decent prop setup for this boat. I dont really plan on doing any power mods. It's fast enough for the river. I'd like to get rid of some blow out, as it takes forever to plane, maybe pickup a few mph.
I should mention this is with k planes.
Thanks for the help
airbats801 is offline
Old 11-28-2017 | 09:38 AM
My suggestion is to call Brett @ BBLADES. There weren’t a lot of sport boat prop options in the 1980’s
BenPerfected is offline
Old 12-02-2017 | 10:10 PM
Rookie's Avatar
I've run pretty much every prop style on my TRS Panther. I believe the best overall props and my favorite handling props are Mirage 3 blade. They carry the bow nice, the boat loosens up and reacts favorably to trim. I had blowing out problems at one time with my original props. The cupping was washed out of them. I had cupping added and they don't blow out any longer. I have never had to use tabs to get on plane again. If you are worried about getting on plane the Mirage PLUS in 23 pitch should be about right.
Rookie is offline
Old 12-02-2017 | 10:30 PM
SB
Huh ?
SB is offline
Old 12-03-2017 | 05:45 PM
hblair's Avatar
Whenever my trans went out I could only hit like 5 mph idling back on one motor lol.
hblair is offline
Old 12-03-2017 | 05:46 PM
hblair's Avatar
I’m with rookie on the mirage props.
hblair is offline
Old 04-22-2019 | 03:04 PM
Late reply, but boat has been on the back burner.
I pulledone of the propsoff today to see what they actually were. Hydromotve HC-CL24 Q-iV props.
Apparently, the common trait with these is slow and hard to plain without blowing out. I'll start looking for a set of used mirage props to suit trs drives. I think I will toss these things up for sale.
Old 04-22-2019 | 07:59 PM
I have a set of BBlades test time only 24P 4-speeds if your looking for another set of 4 blade props.
Topshelf38 is offline
Old 04-25-2019 | 03:41 PM
I think I'm going to do a 3 blade mirage. It sounds like that's the way to go for what I'm doig. Moving g sometimes a lot of people, better planing, and less blow out on sharper turns.
Old 04-25-2019 | 04:38 PM
No problem just throwing it out there in case someone else has any use for these. I have a little too much hp for these now . These def
