-   Scarab (https://www.offshoreonly.com/forums/scarab-41/)
-   -   Iso 33 avs fairing (https://www.offshoreonly.com/forums/scarab/361401-iso-33-avs-fairing.html)
HZ900 06-23-2019 03:01 AM
Iso 33 avs fairing
Looking for the 33 avs fairing that was used on the later models from what I can tell. One like in the pic.https://cimg9.ibsrv.net/gimg/www.off...c18c657a84.jpg
scarabman 06-23-2019 06:24 AM
The 33 AVS had (2) different fairing choices . Base model was an acrylic fairing and upgraded option was the painted aluminum, which is what you have pictured. These were regardless of year of boat.
Dan from Archer may be able to point you in a helpful direction, but for the most part, finding an aluminum fairing will prove to be a challenge. For the acrylic, Anchor Marine in Md was planning on having a mold made for new ones a few years ago but not sure what became of it.
HZ900 06-23-2019 07:51 PM
I have the acrylic one, was wanting to replace with aluminum one. I was hoping to source one used rather than having to have one fabricated. There are a couple people local to me that could do it but no telling what it would cost me. How do I contact Dan from Archer, not familiar with who he is.
scarabman 06-25-2019 02:29 PM
Dan is on here under the screen name Archer. Archer Marine in CA. He is a Scarab guru
Vecor 08-10-2019 04:48 PM
33 avs fairing
I am also looking for the aluminum fairing version. Have you found anything?
articfriends 08-19-2019 01:04 PM
[QUOTE=scarabman;4693278]The 33 AVS had (2) different fairing choices . Base model was an acrylic fairing and upgraded option was the painted aluminum, which is what you have pictured. These were regardless of year of boat.
Dan from Archer may be able to point you in a helpful direction, but for the most part, finding an aluminum fairing will prove to be a challenge. For the acrylic, Anchor Marine in Md was planning on having a mold made for new ones a few years ago but not sure what became of it.[/Q
Have any of you 33 AVS owners ever pumped or ran your gas tank completely dry then filled it all the way? Looking for REAL world number of how much one holds, not the published data of 144, was mentioned once they actually hold 180 but I dont know that to be a fact. In planning stages of my new engines which may be on e85 so capacity is important, not going to pump mine dry right now then fill it with e85 that I might not go to to see how much it takes, thanks, Smitty
Vecor 08-21-2019 07:12 PM
thanks, I will try Archer
