Engine options >
Engine options
Engine options
Old 05-13-2021 | 11:51 AM
Default Engine options scarab 1
I am going with the bbc 454 that i have, and is the starter in different location for marine use, can a truck block be retrofitted ?
Jim Fletcher is offline
Old 05-13-2021 | 01:42 PM
I’d stay with the BB and add a Bravo drive and you’ll be happy for a long time. Replace as much cast iron off the BB with aluminum bits and you should be close to the oem small block.
Caveat: I really know Jack **** of what I’m talking about but that would be my path to explore.
Baja Rooster is offline
Old 05-13-2021 | 01:58 PM
Originally Posted by phughes69
Short answer is no
will the starter location be same on a truck 454 block as it was on the 350 sb that came in boat?
Old 05-13-2021 | 02:19 PM
Im trying to use the flywheel cover that came with boat, also trying to id if block it mark IV or gen V, it has a fuel pump mount but block off plate bolted to it and also has hole for crank sensor on bottom of timing cover ? Any help appreciated
Old 05-13-2021 | 02:32 PM
F-2 Speedy's Avatar
starters are in the same location on a SB and BB, unless a top mount rear CCW starter is used in a trans application
F-2 Speedy is offline
Old 05-13-2021 | 09:37 PM
1st time tryin to post pic. Here she is old but solid transom
Old 05-14-2021 | 04:28 PM
^ looks good!
bajaman is offline
Old 05-14-2021 | 05:16 PM
If you spend some time going through the Mercruiser parts diagrams, you should have a good idea of what you have and what is required to make the swap....
https://www.mercruiserparts.com/part...ndrive-inboard
speicher lane is offline
Old 05-16-2021 | 08:25 AM
Thank you
Old 05-17-2021 | 01:46 PM
Merc had 330hp BBC in front of Alphas for a couple of years. Late 80s maybe? waiting on the Bravo. A friend had one he bought new that lasted until he decided he wanted to hop it up quite a bit, then it didn't make the next summer.
CDShack is offline
