Scarab II pulling engines >
Old 04-15-2022 | 10:05 AM
Thanks for the help, I have no Idea what the mounts are, I guess I will find out when I am in there. They are borg warner transmissions, I do like the idea of leaving the drives in, but I would hate to do all this work to find out the drives are a problem. Time to rethink this. How hard is it to pull with transmissions attached? will it come out as one piece, really tight in there.
Seaweed100 is offline
Old 04-15-2022 | 10:14 AM
F-2 Speedy's Avatar
what is the problem you are having ?
F-2 Speedy is offline
Old 04-16-2022 | 04:11 PM
Rookie's Avatar
Pulling engine w/ transmission is probably the easiest. Only reason I don't is because of the drive issue. As was eluded to earlier... What is the problem? If it's a drive or transmission issue pull them now.
Rookie is offline
Old 04-25-2022 | 10:08 PM
I separate them between the bell housing and transmission. Bell stays with the engine. Have done it this way more times than I care to remember.
28cigarettess is offline
