Scarab 26  extension box ?? >
Old 09-22-2022 | 05:57 AM
Originally Posted by velocity john
could be bow steering did you trim drive up
the thing is that when I’m going let say 50mph and go down with throttle instantly boat wants to go the right . So I gently put trottle so it doesn’t do it . I think that a problem of cable steering ?
Bulitz1 is offline
Old 09-25-2022 | 11:14 PM
Sydwayz's Avatar
Forum Regulator
Boat on the trailer/out of the water, go back and grab your drive and wiggle it side to side. How much play does it have?
Sydwayz is offline
Old 09-26-2022 | 02:53 AM
There is like 3inch of play left to rite and 2mm up and down .
Bulitz1 is offline
Old 09-26-2022 | 04:13 AM
Veteran: Army
3 inches of play? There's your problem.
DrFeelgood is offline
Old 09-26-2022 | 04:22 AM
I don’t have external steering.
I thought it’s normal with external steering
Bulitz1 is offline
Old 09-26-2022 | 05:11 AM
I had the same issue. Play in steering and pins.
underpsi68 is offline
Old 09-26-2022 | 06:02 AM
You need a new gimbal ring and steering pin.
Gary C is offline
Old 09-26-2022 | 07:25 AM
Sydwayz's Avatar
Forum Regulator
Exactly. 3" of play is NOT normal at all. This is your problem.
I would not mess with an extension box. Fix your worn components.
And while you are at it, I would go with a dual ram Imco hydraulic steering. Do the full kit from helm all the way to the outdrive. The wider the footprint your transom will allow, the stronger the setup is.
https://imcosteering.com/imco-catalog-2022-v10.pdf
Sydwayz is offline
Old 09-26-2022 | 11:58 AM
Ok understand, someone suggested the Merc ITS which I really like but can’t find a used one that I can buy. also saw the imco with wings that like too because don’t really want to do holes in the boat .
why don’t mess with extension box’s I see all fast boats have them 😃
Bulitz1 is offline
Old 10-04-2022 | 06:55 PM
I put a Mayfair box and steering on my 26. Up 2" plus a 2" imco short lover, so x is up 4". Haven't run it yet, so no real input for you.
moisturemissile is offline
