-   Scarab (https://www.offshoreonly.com/forums/scarab-41/)
-   -   New 377 owner (https://www.offshoreonly.com/forums/scarab/379513-new-377-owner.html)
Franks292 06-07-2023 07:10 PM
New 377 owner
Hey Everyone. My father and I bought a Scarab last weekend! The boat underwent a partial restoration and repower a few years ago. Recently built Supercharged 540 tall decks with speedmaster 3's. New transom and Freshly rigged back seat to stern. Wanted something with a big cabin and roomy cockpit, even better that it's staggered with 700hp a side! A previous owner deleted the windshield for a race fairing, which looks awesome in my opinion. The boat is far from perfect but with the power/drive combo and solid hull for the money, we couldn't walk away. Here's a few pictures!
https://cimg6.ibsrv.net/gimg/www.off...c95c88bd57.jpg
https://cimg8.ibsrv.net/gimg/www.off...f11717306.jpeg
https://cimg9.ibsrv.net/gimg/www.off...336a96b68.jpeg
https://cimg3.ibsrv.net/gimg/www.off...f2ef52b5c.jpeg
https://cimg8.ibsrv.net/gimg/www.off...87361a164.jpeg
https://cimg5.ibsrv.net/gimg/www.off...17c7ddf29.jpeg
This winter I would like to install full hydraulic steering, new gauges, new bolsters, etc. Absolutely thrilled to finally own a Scarab. Me and my dad have talked about it for years. Any upgrade suggestions welcome!
jeff32 06-07-2023 08:27 PM
I remember seeing it for sale lately! Nice boat ! Nice power for sure!
resurrected 06-08-2023 09:25 AM
Excellent find for sure!
Find out the gear ratio. 1:68 don't have much mesh in the upper gears and will tear them up with that much power and weight.
RSCHAP1 06-08-2023 12:44 PM
Looks nice
The ads caught me eye also
Congrats
1983ScarabIII 06-08-2023 09:03 PM
Very nice. Congrats.
scippy 06-08-2023 10:02 PM
No hydraulic steering?......Sharp boat!
Franks292 06-09-2023 08:20 PM
will do!
Franks292 06-09-2023 08:21 PM
unfortunately no, will definitely be installing it this winter. Thanks!
Franks292 06-09-2023 08:24 PM
Thanks for the kind words everyone!
TomZ 06-10-2023 11:08 AM
Congrats!! Lotta boat there!
hblair 06-10-2023 12:09 PM
Good Looking Boat. Congratulations!
Franks292 07-09-2023 08:46 PM
thank you! Been following your KV resto for a long time, your boat is absolutely gorgeous!
Franks292 07-09-2023 08:53 PM
Update on our recently acquired 377. Unfortunately we had a mechanical failure in the port side engine. Engine has to come out and cam needs to be replaced. Plan on inspecting everything to make sure theres no damage to bearings etc.. Original builder used the wrong distributor gears. Stbd side engine survived by the grace of the offshore gods. Always something with these damn boats. To be continued!...
https://cimg9.ibsrv.net/gimg/www.off...baf793f4b0.jpg
hblair 07-09-2023 09:24 PM
Thanks on the boat. It’s been a long time coming. We were going to run it a few hours today and check again for a few pesky steering and oil leaks. Pulling away from the dock, right motor wouldn’t idle, kept dying. It was running crazy rich. Both motors had been very healthy and would fire right off with just a bump of the starter. We screwed around with it for hours, trying to set the float levels, there’s two Nickerson Holley carbs per motor.
We dropped the right front carb float adjustment screw between the exhaust manifold and couldn’t get to it, so I dropped the trailer and ran to the shop to rob a screw off one of my extra carbs lol. We couldn’t get the engine running right and had actually bumped the pier with the bow when the right motor suddenly loaded up and quit. It left a place we’re going to have to repair now lol.
We finally loaded up and got back to the shop, and being the boat idiots we are, we connected the hose and kept screwing with the right front carb, kept overflowing, couldn’t get the float valve turned down.
Shon says “Let’s check it for trash”, and there it was, an aluminum shard about 1/2mm wide and 1/4” long. Keeping the float valve open. It was a thread from when I took the fuel lines loose to pull the blowers off a month or so ago.
I tell this story to let you know I feel your pain brother! These boats will break your heart on the regular. You have to be the kind of guy who doesn’t learn lessons well. 😂
hblair 07-09-2023 09:28 PM
I wonder why the cam did that? Have you looked at the other side?
Franks292 07-10-2023 08:57 AM
Original builder used the wrong distributor gear. Should have used a bronze or poly gear. The stbd side survived but was getting ready to do the same thing.
hblair 07-10-2023 09:16 AM
That's what I figured. Maybe luck will be on your side and nothing else got damaged. Are you guys going to try to pull the motor soon?
Franks292 07-10-2023 09:35 AM
I'm already expectiexpected damage that way ill be happy if there isnt hahaha. Gonna try to have the engine out by the end of the month.
Franks292 07-18-2023 08:59 PM
https://cimg4.ibsrv.net/gimg/www.off...fa6d714936.jpg
UPDATE! Engine was pulled out today, hopefully have the full damage report by the end of the week. Expecting the worst but fingers crossed hoping for the best (considering the situation)
Scarab3asd6 09-08-2025 11:19 PM
Good looking boat what ended up being the outcome?
Franks292 09-09-2025 07:56 AM
boy oh boy has alot happened since i last posted about this boat. The TLDR version is Wesco fixed the engine, and put it back in the boat. I ran it for one weekend and then scattered the STBD side outdrive. Since then I've pulled both engines out and pretty much stripped the back of the boat. Got another set of #3 drives that have been shortened 3 inches and another set of transom assemblies. I decided to pull the 540's for a faster hull. Wesco building me a pair of 468's with blowers that should make around 675hp each on 5 pounds of boost. Figure with the shorter X dimension and the 468's with better props the boat should run about the same if not better than it did.
https://cimg3.ibsrv.net/gimg/www.off...3580489609.jpg
hblair 11-12-2025 07:37 PM
What kind of speed were you running with the original Setup?
ICDEDPPL 11-12-2025 08:22 PM
I`d hate to tell ya but this boat will keep sucking money out of your walet like it`s going out of business.
Been there done that for 12 years.
I could have bought a new boat with the money I sank into that Cig.
Franks292 11-14-2025 11:57 AM
Ran 70mph GPS in flat water. Boat took forever to get to 5,000 rpm coming from 4000. Engines still had 600rpm left in them.
Franks292 11-14-2025 12:01 PM
It already is. Deciding to build another set of engines and set the 540's aside for something else reeeeeally wasn't a smart financial decision on my part.
hblair 11-14-2025 05:58 PM
please do not use the terminology “smart financial decision” in my presence. Thanks 😀
hblair 11-14-2025 06:03 PM
I thought that’s why we were all here. To throw good money after bad etc. Some people drink, some gamble, others drugs. Me? Old boat addiction. I might need an “old boat rehab”
Franks292 02-08-2026 12:18 PM
Just a little update, had a new cover made, all 4 carbs rebuilt, purchased rebuild kits for the Weiand 256's from TBS since I didnt like how the one felt spinning by hand. Cylinder heads are finished, rotating assemblies are balanced, blocks are machined. Gotta buy oil pans still. Got some fiberglass work i want to do to the boat while its still apart. Want to do a full bulkhead behind the back seat (eliminate the hull shake which most scarabs have with the factory half bulkhead), replace the vertical supports in the engine compartment and some other odds and ends. Here are some pictures. Been playing carpenter with my house so I havent gotten much else done on the boats.
https://cimg1.ibsrv.net/gimg/www.off...7f6b10edc8.jpg
Brand new Sunbrella cockpit cover, extended over the bilge vents.
https://cimg5.ibsrv.net/gimg/www.off...c5ae78611d.jpg
After cleaning 10 years of dust off the blowers. Pic was before i pulled the carbs for rebuild.
hblair 02-27-2026 07:34 PM
Looking good!
