-   Scarab (https://www.offshoreonly.com/forums/scarab-41/)
-   -   Stand off boxes on a 34 Scarab??? (https://www.offshoreonly.com/forums/scarab/55143-stand-off-boxes-34-scarab.html)
Tinkerer 07-22-2003 07:49 PM
Have any of you guys put standoff boxes on a 34 SCARAB??? What results have you gotten???
Mine is a 92 with IMCO 2 inch shorties. I was thinking on putting boxes with 3 inch rise. The props don't cavitate or break loose on turns now with the short drives but they do slip on take off. The boat must be able to get on plane without blowout problems. I was thinking on getting the new 5 blade MERC props to go with it. I am running 28 bravos now with 600 HP. The boat tops out at 77 MPH GPS. I run at 7.5 on the cable drive indcators for max speed-- Neutral drive setting is 3.5-- The boat will get on plane even with the drives set at neutral with almost no difference from all the way down. Thanks Steve
Scarab3DMC 07-28-2003 11:36 AM
Tinker... YOU STUD!!!!!! trying to get that beast into tripple digits?????????????
Tinkerer 07-28-2003 08:36 PM
Hey I figure with boxes, Hyd. steering and 700 HP 540+ cubes it should do at least 90's.
Seriously I NEED full hyd steering and if I was going that route I should install stand off boxes at the same time.
The boat needs more bow lift and the boxes will give it more leverage so I won't have to trim so far to lift the bow.
redscarab3 07-29-2003 06:51 PM
Hey Tinker
let me know when you get it all Dialed in.
I may want to buy it.
Tinkerer 07-29-2003 09:13 PM
Yeah you are probably just about right. Just about the time I get it all done just the way I want it - it will be time for another boat.
CustomRigger101 08-06-2003 09:10 AM
know a guy that redid a 29 with IMCO"s big box and 430 kplates.. you'll love it.
Tinkerer 08-06-2003 10:59 PM
What changes did it make???
Did it help the top speed and help in bow lift???
