Page 1 of 2
Go to
-   Scarab (https://www.offshoreonly.com/forums/scarab-41/)
-   -   Whats up with exhaust on the 22 scarab? (https://www.offshoreonly.com/forums/scarab/97873-whats-up-exhaust-22-scarab.html)
airshares 03-08-2005 03:37 PM
I noticed when looking my exhaust tips from the behind my boat one tip is appears to be where it should be on the transom and the port side tip seems slightly off center. The exhaust appears stock its a 454 with corsa quick and quiets and no other holes or patch jobs on the transom......is this normal is did someone with "wall eye" vision install my exhaust??
airshares 03-08-2005 08:07 PM
Re: Whats up with exhaust on the 22 scarab?
Anyone? Anyone? Come on all it takes is for one of you with a 1995 or newer Scarab 22 to look at the back of you boat and check to see if your exhaust tips are centered........Please. Im dying to know if its just mine that messed up.
SCARABJ 03-08-2005 08:29 PM
the mold was set up for a small block that is why it looks like they are on the outside of the cutouts on the swim platfrom.james
airshares 03-08-2005 09:57 PM
Yeah but on mine only the port side tip is on the outside of the swim platform mold in. The starboard side is directly under it. Is this a screw up ??
SCARABJ 03-09-2005 06:38 AM
Quote:
no every one i have seen has this issue.. i had one and 4 of my buddies have them. they all have this except the one with a 350mpi
outriggers 03-09-2005 08:16 AM
I know it doesn't match the molded parts of the platform. I always thought they were for the sb. But I did think they wrere the same on both sides. It's cold as a ba$tard out and I have the boat next to the back wall in my building, so I don't know if I can get you some pic's. I will try in the next few days. This brings up a good question. Are the holes in the standard bravo location? They dont go strait out. The Corsa pieces seem to have a angle then go out. pic's soon. Doug
outriggers 03-09-2005 09:37 AM
3 Attachment(s)
Man it's cold with your shoes off in the boat! See what I mean with the offset and the Corsa's. If I went to different exhaust do I need some custom work? I use regular tip's with slip in muffler's. Doug
airshares 03-09-2005 12:49 PM
Hey outriggers, Thanks for all your input. That answers my question. i cant remember what my exhaust looks like under the swim deck. I just noticed that from the outside of the boat looking at the transom the port tip was off center compared to the starboard tip. I boat this boat as a repo so I just figured someone did a hack job on the exhaust install....but the transom looks stock and the exits holes dont look messed with.
ga1990 03-15-2005 02:10 PM
Am I the only person who has a Scarab 22 with thru-prop exhaust? Well that's gonna change this spring...I picked up a set of Silent-Choice diverters...any advice on tips? The Rex-marine ones look pretty nice.
Longrange4u 09-11-2005 08:21 AM
ga1990 Did you make this upgrade? Any problems? Got pictures?
I have thru-prop exhaust and would love to change it to something better... need some advice!!
1  2
Page 1 of 2
Go to
