Go Back  Offshoreonly.com > Owners Forum > Sea Ray
any muffler insight? >
Old 09-28-2007 | 07:59 AM
Default any muffler insight?
do you guys happen to know exactly our mufflers work? is the whole thing hollow inside or are there baffles and such? my 22 has one that apparantly has a small leak that has devoloped and I'm trying to figure out the best way to fix this. I found some aftermarkets which are close to the original thing (the vernalift group
http://www.centekindustries.com/exha...ndex-frame.htm
but since its just a small leak I'd rather not have to buy new ones if I can avoid it. I love the sound with the mufflers so I'd rather not ditch them...although I am curious what some of the other styles cintek makes sounds like.
blckkat is offline
Old 09-28-2007 | 11:34 AM
I have a set I took off mine if you are interested. PM me.
Tow-N-One is offline
Old 09-29-2007 | 10:28 AM
SeaRay Jim's Avatar
What mufflers, I don't need no stink'n mufflers....
SeaRay Jim is offline
Old 10-02-2007 | 07:37 PM
When I installed my 502, they started to leak from the volume going through. Remove them, mine came apart fairly easy..separate the upper from lower (make lines to re-align later)
Trim about 3'' off the inner part of exit tube, this will help breath easier, without noise gain. the simply start wrapping the seams with fiberglass matte. Sand high spots if needed,smooth out, paint. That is pretty much it.
If anybody has an extra set I am interested!!! call my cell anytime, thanks
(413) 822-3783 Jason
pocketchange22 is offline
Old 11-01-2007 | 08:15 PM
Hadn't thought about selling my mufflers but I might! Kindda thought I might use them 1 day if I go back to stock. Mine have very low hours. What would you pay for a pair in good shape?
pachanga is offline
Old 11-26-2007 | 03:24 PM
bcfountain's Avatar
Registered User
Default mufflers
do yourself a favor and get rid of the mufflers and call brownie at stainless marine and get them to make you the long risers and the manafolds for your pachanga.they have made quite a few and they work great.better gas consumption and better performance.easy to install.beat $$ you will spend.
bcfountain is offline
Old 01-14-2009 | 12:43 PM
pocketchange22
Do you have any pictures of when you had your muffler in pieces? I am looking for info about how it is designed inside and would really appreciate if you could post, or email some.
And of cource if any one else has some too.
[email protected]
Berglund is offline
fastninja
08-01-2008 06:02 PM
Sydwayz
9
08-11-2005 01:48 PM
