Go Back  Offshoreonly.com > Owners Forum > Sea Ray
PAchanga 32 gauges >
PAchanga 32 gauges
PAchanga 32 gauges
Old 03-27-2011 | 06:39 AM
Default PAchanga 32 gauges
what about removing the angled "buckets" that mount the gauges? And mounting the gauges with bezels to the dash directly, anybody? I was thinking the hole might be too large..Looking to upgrade the orig gauges this spring
Thanks!
jcburris is offline
Old 03-27-2011 | 11:26 AM
Thanks!
I've been thinking the same thing, pachanga27 changed his gauges out and did a post on it, you can do a search on it and get some ideas
Flamingo 42 is offline
Old 03-29-2011 | 11:12 AM
you can't do it with the stock gauges the bezel is the exact same size as the factory hole. I had the same issue on my P-22, I had to go with the 2 5/8 gauge and the bezel worked then. Hope this helps IM me if you have futher questions. This is where I got my Auto Meter gauges they have a ton of different styles and they were great to deal with.
http://www.egauges.com/vdo_marM.asp
Justin
pachanga27 is offline
