alpha gen 1 VS. alpha gen 2 >
Old 05-16-2003 | 11:23 AM
HiPerf2000's Avatar
Default alpha gen 1 VS. alpha gen 2
what is the main difference between the gen1 and gen2 alpha's.
a friend of mine asked me if the gen2 will work on a gen1 housing. So i guess that is my main question. will it bolt up and work?
HiPerf2000 is offline
Old 05-16-2003 | 11:25 AM
patrick22309
Default Don't think so..
My alpha 1 looks different and my friends alpha gen2.
Old 05-16-2003 | 11:40 AM
If your asking, will the
drive ( gen II) bolt up to the
gen I bell housing?......... No.
JaayTeee is online now
Old 05-16-2003 | 01:30 PM
turbo2256
A gen 1 will bolt up to a gen 2 gimbal with some machinig to the gimbal price is about 150 dollars. I looked into putting a Alpha SS on a gen 2 a couple shops said they could machie it to fit. still have the SS for sale. Sold the boat I was going to put it on.
Old 05-16-2003 | 01:42 PM
jaroot's Avatar
Default Alpha SS on Gen II transom
I just did all of the engineering, machining and installation of an Alpha SS on my GEN II transom Assy this spring.. there is a short thread @ donzi.net which shows some of the modifications required. takes longer to get the bellhousing off of the transom assy than it does to do the modification. Bout 50 bucks in parts and an hour or two of mill work including the setup time...
i have not done the GEN II onto a GEN I transom assy but i believe it could easily be done. you will need GEN II trim cylinders and cross bars, etc. You will need to swap the upper shift shaft from a GEN I to a GEN II (gen II is longer and narrow). You will also not have the benefit of remote oil monitoring.
jaroot is offline
Old 05-16-2003 | 02:15 PM
HiPerf2000's Avatar
Yes.... that's what i wanted to know.
thanks.
scorpion king
Drives and Lower Units
5
09-06-2007 05:14 PM
Fenderjack
3
06-24-2007 10:45 PM
superiormgmtco
5
01-29-2007 05:31 PM
srracer
2
04-20-2006 03:49 PM
Raven
6
06-09-2003 06:18 PM
