Why mount tabs horizontal
Old 11-26-2006 | 08:38 PM
Hot Boat's Avatar
Team Dysfunctional
Default Why mount tabs horizontal
I notice a few race boats at Key West run there tabs horizontal. what is the reason behind this. I going to be reinstalling my tabs next week and want to know what would be better.
If it aint broke .... I can break it....
Hot Boat is offline
Old 11-26-2006 | 09:10 PM
mcollinstn's Avatar
Default Re: Why mount tabs horizontal
you ever snowski?
how'd you learn to stop?
didn't you learn to snowplow with the skis tucked in towards each other?
Let's consider an extreme..
What happens when you mount the tabs VERTICAL and put them "down"?
You snowplow, right?
So if you go from vertical (fully snowplowing)
to horizontal (no snowplowing), then you can see that the more you stray from horizontal, the more snowplow effect you will have when you tab below neutral.
When tabs are mounted at a matching angle to the deadrise, and you run them neutral, then there is no snowplow, there is just additional "hull length". This is useful. But when you have to run them below neutral, you start snowplowing.
There are arguments both ways. I guess the real answer depends on how much tab you need to run at racing speeds.
mcollinstn is offline
Old 11-26-2006 | 09:16 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Also heard of the snowplow effect described above.
US1 Fountain is offline
Old 11-26-2006 | 09:20 PM
epeek's Avatar
Originally Posted by mcollinstn
you ever snowski?
HEY!! Your back! I look foward to your insight. Always
top notch.
Paul (hot boat). It's because its a Fountain....always on
the cutting edge.
epeek is offline
Old 11-26-2006 | 09:26 PM
berns29scarab's Avatar
if beek boats do it, it must be right no ?
ONLY KIDDING !!
Have also gotten the snowplowing explanation makes sense to me but who am i ?
berns29scarab is offline
Old 11-26-2006 | 09:37 PM
Hot Boat's Avatar
Team Dysfunctional
I have a 28' single engine. I only use the tabs when its rough water or during a poker run. When I do use them I dont need much tab, either flat with the hull or slightly lower, just enough to give the hull some extra length to keep the bow from lifting.
mcollinstn from what you said it sound that I would be best leaving them where they are , and using them more as a hull extension.
Hot Boat is offline
Old 11-26-2006 | 09:40 PM
if they are horizontal yes...
Old 11-27-2006 | 01:01 AM
AIR TIME's Avatar
JEB BROWN was doing that back in the early 90's on his race boats
AIR TIME is offline
Old 11-27-2006 | 02:34 AM
do the water flow calcs b4 you decide to mount them. I have them horizontal on my fountain now, but I tried that on the Venom earler this year and I found them to be useless(tabs in down position caught 2 3/4" of a 30" tab) in that position so I went back to matching the bottom. Boat design detirmines alot when making this decision
F1-00 Racing is offline
Old 11-27-2006 | 03:47 PM
top notch.
the cutting edge.
Installing the tabs horizontal is a very old idea. Far from cutting edge. CanDo
CanDo is offline
