800-900 hp for bravo xr's >
Old 02-13-2008 | 01:10 AM
Nauti By Nature's Avatar
Default 800-900 hp for bravo xr's
building new motors for my 38 fever with xr drives
will they be able to stand up to 850 hp without modification
if I keep them in the water as opposed to in and out of water !
Any worthwhile changes that can be done to them ( old style xr's).
Nauti By Nature is offline
Old 02-13-2008 | 09:44 AM
marinetrans's Avatar
The MAXX Machine tower, clutch shaft , billet top cap and non-full compliment needle bearings w/ your XR gears.Seems to last the longest of all setups.
marinetrans is offline
Old 02-13-2008 | 07:28 PM
what will that stuff cost about? and what type of hp rating would it have?
Old 02-13-2008 | 07:38 PM
Somewhere around 4500.00-5000.00 w/ new xr gears and a Max joint set up. Expensive but pretty stout.Same power you are running,knock on wood,they have been excellent.
Old 02-13-2008 | 07:58 PM
Strip Poker 388's Avatar
Wish I was your drive guy$$$$
All the bravo style drives will break soon or later with that power.All!
Strip Poker 388 is offline
Old 02-13-2008 | 08:16 PM
The trick is to find out before it happens. Reading magnets,color of lube and recognizing shifting problems help.XR gears are not known for their longevity but the near net forging makes them the strongest ones to date.With the stock race tower there is .010 to .015 of deflection and the gear/needle bearing (full compliment) acually "chatters". The Maxx tower has nearly no deflection of the gear, using a non full compliment needle bearing.
Old 02-13-2008 | 08:21 PM
Talking
How about if he pulls 4 plug wires off.
Old 02-13-2008 | 09:18 PM
Haa Haa, Sorry.
No way you will need to modify or replace.
RBeyer is offline
Old 02-14-2008 | 07:09 AM
NJSONIC's Avatar
Max Machine-They wont last on a 38'-with 800hp. I know!!!! Konrad ACE's do!!!!!!!!!
NJSONIC is offline
Old 02-14-2008 | 09:32 AM
how many horses are you putting thru the ace's ?
