502 Mag Mpi Oil Pressure At Cruise
Mine is the same as Dave M's. Right around 4000 no matter what rpm's. After a hard run it idles at 20 and I usually try to keep it above idle to help the oil cool down before I let it idle. I probably wouldn't be concerned with 35-40 on an electric gauge. I agree, I have done a lot of older 454's and always had 55-65, but I guess that is how the gen 6 502 is. All of my friends 502's are the same, but it hard to get used to.
After reading the above I guess I was'nt the only one wondering all this time.
Same situation .. 98/99 502 mag Never seen over 40 psi. most of the time runs around 35 or a tad higher. Guess I can stop worrying now .
Can't trust the reading on an electric gauge. Might be spot-on but the point is that you can't trust them.
Always good to have a decent mech gauge on the motor where you can pop the hatch and compare readings when the elec on the dash causes you concern.
Dave M,
My stock 454 mag show only 40lbs no matter what. I had mechanical gauges installed to verify. They show 56lbs. That made me feel better, but i still what to see it on the gauges. The port motor gauge has finally moved up to 50+ lbs. Starboard stuck on 40. I think either its a sending unit or gauge issue.
Mine ran 55- 60 psi.
