Garden Sprayers to Change  Drive Oil >
Old 05-09-2007 | 04:11 PM
Craney's Avatar
Default Garden Sprayers to Change Drive Oil
How many are using garden sprayers (the type you pump up) to change your drive oil? Or should I just use the old push pump on the 2.5 gallon jug.
Craney is offline
Old 05-09-2007 | 04:21 PM
thats what we use ( garden sprayer)
Larry D is offline
Old 05-09-2007 | 04:31 PM
TSPM's Avatar
Us too ...........
TSPM is offline
Old 05-09-2007 | 05:14 PM
mbones's Avatar
mbones
the hand pump on a 5 gal bucket workes good for me
mbones is offline
Old 05-09-2007 | 06:00 PM
Veteran: Air Force
I rigged up a garden sprayer and it works like a champ.
Old 05-09-2007 | 08:58 PM
gsmith9898's Avatar
how do you use the garden sprayer?
gsmith9898 is offline
Old 05-09-2007 | 09:17 PM
mtgbiker's Avatar
a tire valve mounted in the sprayer that you pump up with your air compressor works good and saves a lot of hand pumping
mtgbiker is offline
Old 05-10-2007 | 06:48 AM
CigDaze's Avatar
Yep. Same here with the garden sprayer.
Just cut off the metal end of the sprayer (leaving the valve intact, of course), zip-tie the clear plastic hose with the drive's screw-in fitting onto the end, and viola! And as mtgbiker mentioned, you can drill a hole into the canister and install a tire valve so you can fill it with compressed air and not have to pump. Works awesome.
Something like the pic below.
Oh, and this sprayer tool also works excellent for bleeding brakes on your truck!
CigDaze is offline
Old 05-10-2007 | 07:41 AM
Shore Thing's Avatar
slap the word "marine" on the side of that and market it for $64.99.
Shore Thing is offline
Old 05-10-2007 | 08:06 AM
OldSchool's Avatar
I use a 5 gallon bucket and the lid with a big pump on it....but my drives take 4.5 gallons each. It works quite well for me.
OldSchool is offline
