Fountain swim ladder
Here is the new fold up swim ladder I just installed on my 27 Fever. It took all of about an hour to install, it uses the toggle bolt type hardware. Sells for $285.00 + Tax and shipping about 2 weeks. Here is the website [email protected] My wife love this step. Hint Christmas is right around the corner
I'll need to take some more pics on a lower resolution I can't shrink them down enough
Bought the same ladder this spring only in the white powdercoat,wrong choice, it tends to catch exhaust soot. I was worried about the anchors they supplied but they said up to 300 LB.
..good thing I lost some weight
35 White Lightning, thanks for the pictures, that does look pretty clean on there. So, you did use the the hardware they sent with the ladder. Elba told me that the backing nuts are steel verses the outside ones being stainless. Did you coat the steel part with anything before you shoved them through the holes? Thanks also for the tip on the white powered coated one because I was going to go with it until you mentioned the soot..... If you have any pictures on the trailer from the back I'd like to see them.. Thanks again Speed
I bought the same ladder for my 42. Works great, holds my fat azz with no problems. Only problem I have had is the insert anchors are not SS and 1 of them has some rust. I use the boat in salt water. I don't think it will be an issue, but I am keeping my eye on it.
I have a 32' Fountain and am looking for a solution. I'm thinking i would want more steps than these spring steps. I noticed on the aqua performance website, they have a new telescoping ladder but i dont have any idea how i will get back in the area where the anchors need to be mounted on this Fountain??? there is a firewall back behind the motors blocking that area. How did you Fountain guys make this work?
