CMI Air Actuated Mufflers >
Old 03-01-2019 | 02:51 PM
Anyone have these? Quick question. When the boat is off and you close the flapper how long does the flapper stay closed. I’m bench testing mine and it only stays closed a few seconds after closing them if the compressor is shut off. I didn’t know if the engine was running if that would help them stay closed.
Alwhite00 is offline
Old 03-01-2019 | 04:07 PM
Scarab28's Avatar
That's an indication of a leaking cylinder or leaking hose connection. Run some soapy water over each connection as you run the pump. You'll easily find the leak. They should remain closed overnight.
Scarab28 is offline
Old 03-01-2019 | 05:36 PM
I believe my solenoid is bad, just ordered another one. I’ll keep everyone posted.
Old 03-01-2019 | 06:07 PM
Rookie's Avatar
Originally mine would stay shut for days in storage.
I believe my solenoid is bed, just ordered another one. I’ll keep everyone posted.
I put a check valve inline so the air did not bleed back through the pump.
Rookie is offline
Old 03-01-2019 | 09:44 PM
Mine will stay closed for about an hour.
FYI, the ends on the actuator cylinders will unscrew and there are O rings inside that can be replaced.
Old 03-02-2019 | 05:23 AM
i had to replace my cylinders as both were cracked next to the fitting. It is really thin in that spot, bad design. I replaced them with Bimbas, 1/3 the price and all stainless/aluminum construction. Work great. My solenoid was leaking.
Old 03-03-2019 | 07:09 PM
Rookie's Avatar
Part number? I'm to lazy to go measure my cylinders. I assume the cylinders were spring return.
Rookie is offline
Old 03-03-2019 | 10:04 PM
yes, spring return. I’ll get the part numbers tomorrow.
Old 03-04-2019 | 07:00 AM
You need to take the pin out of the end. (Tap out with hammer ) and these do not have a line from the vent. This did not matter to me as its a new install.
