View Poll Results: Who makes the best blower/supercharger?
Voters: 372. You may not vote on this poll
http://www.kennebell.net/superchargers/gm/gm81/gm81.htm
Very high tech and smooth integral operation I am told.
Originally Posted by John NY
Roots are inefficient - they are blowers where centrifigals and screw (i.e. whipple) are compressors. The inefficiency equates to heat. Since you have an unlimited amount of cold water available, air to water intercooling the inlet charge addresses this nicely.
For large cubic inch applications which are not running at seriously high RPM, a Whipple is better suited than a centrfigal. Centrifigals are better suited for very high RPM applications.
For a typical boat, large cubic inch engine with redline under 6,000 RPM, I would say the Whipple is th best choice for the application.
However, a turbo would be even better as there is less sacrificial loss of horsepower - no belt to drive it. You can run less bost and make same HP levels. I am not sure about the whipple, but a centrifigal can easily eat up 80 HP just to run it. So to make X horsepower you need to run more boost than with a turbo.
Turbo's are more complicated setups and generally cost more. Not sure why there aren't more turbo's for boats as they are better solution for forced induction applications. Would be harder to have standardized kits as packaging would quite different for different boats. Superchargers allow more standardization and this makes it cheaper. If I were building an all out effort (i.e. custom, cost is no object), I would be doing a turbo setup.
John
John
Originally Posted by joe900sc
Doesn't turbo lag create throttle problems in big water?
Twin turbos (more $) will generally eliminate turbo lag - at least in cars. A centrifigal would in theory have the same type of issues as it won't make much boost at low RPM, but when the power comes on it does it big time and just keeps coming.
I haven't played with marine applications, so not sure if there is an issue.
John
Roots blowers dump the fuel air mix straight down, so you get even distribution. Screw compressors move the fuel air mix to one end, so you get plugs in the front fireing lean and plugs in the rear fireing rich. Turbo's provide marine grade night terrors...a serious sleeping disorder
Originally Posted by Reed Jensen
Do a turbo set-up.... in theory they work great... on an engine that runs at a constant speed like an airplane.. they are the standard. Put one in a boat and watch how quickly corrosion destroys everything... Watch as everything welds itself together from the heat and electrolysis...I had twin turbo set-ups on my engines.... no way to plumb in waste gates at the time... and no way to protect everything from the heat of the turbo other than a water jacket... water-jacket a turbo and you lose efficiency.... so .... still want a turbo?
I've played with forced induction but not in marine applications. Seems you've tried it and there are application specific issues!
John
John
For sheer big HP ( BOOST) PSI, the problem is that they don't throttle well because of the dramatic overdrive, they hate stopping and starting and so do the belts
Whipple's work very well with fuel injection but the big inch ( quads) are also fighting some belt problems when throttled hard ( check the belt routing on the Merc 1075's
Millions have been spent trying to make gas marine turbo's work, Tom Gentry gave the best of the best an open LIMITLESS check book and they found power but not a better package.
So pick your poison, the best Supercharger is the one on someone else's boat
) Millions have been spent trying to make gas marine turbo's work, Tom Gentry gave the best of the best an open LIMITLESS check book and they found power but not a better package.
