View Poll Results: Who makes the best blower/supercharger?
Voters: 372. You may not vote on this poll
#112
Originally Posted by Byrdman
What are the discharge temps vs. the water temp.and air temp. in...at what boost???....do you answer the phone faster than rodger ???...How much can you over drive this unit??...100 percent??
Mag/aluminum rotor max speed 22,000rpm.
Rotors are flipped from prior designs, so it's being driven off the smaller gear, which is 33% smaller.
Faster than Rodger, not sure, never called the guy. Talked to Norm a couple of times, but he no longer owns PSI.
For me to post discharge vs. power consumption vs. boost, vs rpm would be quite a long message. Give me an example and I'll give you some numbers.
W305R next to W200ax:
#115
More blower porn...here's the new design twin blower system. It has a 100 HP advantage over the PSI at the same boost level. Easily adapted to different HP ranges by using different Vortech blowers on our gearcase. 12 week delivery if you get into the next production run.
#116
#117
Well....obviously i wish we had met earlier in the game....I have to dig up my garbage from a year ago...and call you...you sound like zul....he needs to look at this thing...your dyno...I will have to look at the dyno sheets....and ask more questions....on the next pull.....your stuff is totally hot and from my issues i can see you have made some good corrections that I had to overcome...nobody listens to me about the belt issues...I demanded the dual pullies but was told to stick it..I think I will yell again now...but I see you have it....your ahead of the game....good for you!
#118
#119
Originally Posted by JCPERF
Did you have a PSI on that dyno that you backed to back to yours?
The axial entry compressor is higher flowing than the radial no matter what though, the radial entry has lower VE because the rotors leak more air when there not sealed 360 degrees. Roots do this as well, but there VE is way, way down from a screw compressor.
Thanks,
Dustin
#120
look now everybody is in front of psi.....they are not that dumb....
and when you do a psi motor....you have to make boost to get the effects of the blower discharge temps....motors do not like boost....hmmmm...
