600SCi Upgrades >
600SCi Upgrades
600SCi Upgrades
Old 12-05-2006 | 04:52 PM
Default 600SCi Upgrades
Hey does anyone know how to upgrade the 600Sci's to gain some more HP? I was thinking about possibly ordering the 700's blower pully, ecu, & intercooler. Do anyone know if that is the only thing that is changed? Does anyone know what is the max boost pressure we can run on that motor?
-Rob
gto4evr is offline
Old 12-05-2006 | 05:16 PM
rmbuilder's Avatar
MarineKinetics
Default Re: 600SCi Upgrades
gto,
The cam profile is very different between the 600 SCi and the 700 SCi.
Regards,
Bob
rmbuilder is offline
Old 12-05-2006 | 11:03 PM
ok so it looks like i would need an ecu, pully, camshaft, & larger intercooler. Does anyone have an idea where to get these parts? I could order them from mercury but i would need a 700sci serial number. Thanks- Rob
gto4evr is offline
Old 12-06-2006 | 01:59 AM
You would probably be much better off to sell the 600sci's and build some custom power if you want 700hp.
Old 12-06-2006 | 07:21 AM
Pat McPherson's Avatar
I agree with Griff on this one.
I have a friend with a 600SCI in a 30' Super. He has researched all avenues to turn his 600 into a 700. The ecu and other parts from Merc are big big $$. You can replace the ignition and computer system with MEFI 4 but then you lose the smart craft.
Patrick
Pat McPherson is offline
Old 12-06-2006 | 12:36 PM
alright thanks guys, guess will just have to wait and do the complete engine and drive job when they finally quit. Appreciate everyones advice. -Rob
gto4evr is offline
Old 12-06-2006 | 04:33 PM
From what I have heard, the Mercury 600's dyno well over 650HP...
HALLETT FAN is offline
Old 12-06-2006 | 07:39 PM
You guys give up to easy. I bet by spring someone will be able to get around the system.
z.zuperboat is offline
Old 12-06-2006 | 07:49 PM
Hey Zup,
For sure you can get around/replace the system and turn up the boost on a 600SCI. There are lots of Whippled 502EFIs making 700+HP.
I'm quite sure that AZ Speed, Precision EFI, Tyler Crockett, and other builders could provide a new ignition, harness, and MEFI 4 ecu ready to go.
The problem is, you would have to be willing to loose the Merc Smart Craft.
Patrick
socalstone
07-28-2011 09:36 AM
tgersx
06-26-2007 10:01 AM
tblrklakemo
Baja
8
08-29-2006 08:41 PM
Back4More
4
05-09-2005 03:46 PM
