Go Back  Offshoreonly.com > General Discussion > Trucks, Trailers and Transportation
Converting to Electric/Hydraulic from Surge >
Old 04-06-2007 | 07:40 AM
Panic Button's Avatar
Emerald Coast of Florida
Default Converting to Electric/Hydraulic from Surge
I'm going to convert the trailer to E/H. Anyone have any pictures on where they mounted the pump and break-a-way box on the trailer? I really hate to drill the steel trailer to re run wires and brake lines. The line currently from the surge cyclinder to the lines has a hole on top of the tongue that the brake line runs thru, so I need to drill atleast 1 hole.
Thanks-
Panic Button is offline
Old 04-06-2007 | 07:42 PM
That's what you have to do...each installation is alittle more different then the one before. But it is not very difficult
here a couple picks of mine...I don't have any of my friend's when we did his, but I can get some if need be
Attached Thumbnails Converting to Electric/Hydraulic from Surge-dscf0036.jpg   Converting to Electric/Hydraulic from Surge-dscf0037.jpg
enticer is offline
Old 04-06-2007 | 08:30 PM
bowtie's Avatar
What did you do with the coupler?
bowtie is offline
Old 04-06-2007 | 08:57 PM
bowtie....are you asking me? and what is the coupler....
enticer is offline
Old 04-06-2007 | 10:00 PM
The pictures are exactly what I was looking for. As for the surge actuator, I'm leaving it in place.
Old 04-06-2007 | 10:16 PM
the BrakeRite is a different model as what my friend has and installed. He used his existing surge actuator. Mine is all built in the unit mounted on the side and the battery in the black box.
enticer is offline
Old 04-07-2007 | 12:59 AM
scottc's Avatar
Very bad idea to leave a surge system in place after disabling it. You must either weld it solid or replace it with a new coupler. Failure to do so will result in banging of the coupler. Also do not forget the break-a-way switch.
scottc is offline
Old 04-07-2007 | 05:40 AM
cig1988's Avatar
Soup to nuts what does it cost for the conversion ? Link to source ?
cig1988 is offline
Old 04-07-2007 | 08:38 AM
Break-a-way box was $59, E/H actuator was $560 shipping $20. I got mine thru www.easternmarine.com
Old 04-07-2007 | 05:06 PM
bowtie's Avatar
I was talking about the acuator, I wouldn't want to leave it on without being used. 2 of my trailers have surge brakes and I am converting, just looking for ideas on what coupler to use.
bowtie is offline
