Need Power Steering hose fitting thats on the rams >
Old 08-23-2007, 05:17 PM
Strip Poker 388's Avatar
Default Need Power Steering hose fitting thats on the rams
I have had 2 failures on my Mayfair Steering lines on the steering rams.The rubber is failing inside the fitting ,the hose it fraying on the end and coming apart.Leaking and loosing steering I have the tool from Marine Machine to put them together etc, The rubber lines are I guess getting old ?
Were can I buy the chrome plated brass fittings in the pick?
Do they make a better hose than the Parker 225-6 hose?http://www.parker.com/hpd/products/s...sp?catdesc=225 I am guess thats what I have ?
Or should I just buy the Stainless ones form http://www.cpperformance.com/detail.aspx?ID=533 already made up?
http://www.hydraulichouse.com/search...nufacturer=225
Pick has mandrel tool in it
Attached Thumbnails Need Power Steering hose fitting thats on the rams-emerald%2520beach%2520poker%2520run%25208-2007%2520098%2520%2528large%2529.jpg   Need Power Steering hose fitting thats on the rams-myco%2520trailer%25208-14-2007%2520005%2520%2528large%2529.jpg
Strip Poker 388 is offline
Old 08-23-2007, 05:30 PM
mikes280's Avatar
i alweays use all stainless. mine came from wpm
mikes280 is offline
Old 08-23-2007, 07:04 PM
Stainless is nice that the aeroquip or parker is probably tougher. If you kink the stainless its done, Most stainless lines are just teflon hose inside.
Jim
MOBILEMERCMAN is offline
Old 08-24-2007, 11:41 AM
did you call marine machine...what's the guy on here that does steering , allan4 or something??
open87 is offline
Old 08-24-2007, 12:14 PM
Bing said use rubber,Ya know how he is ,real friendly on the phone
The guys doing the stainless are saying it want hold up is salt and will tarnish,Ive seen alot of stainless hoses on boats
Ill call wpm and see,Imco looks to have some also
Old 08-24-2007, 04:41 PM
yeah , real friendly ...
i don't think sean made his up and i have not done mine , i have the fittings and was going to go with the non braided...
but.....
not like i wan't to do those lines twice too....
open87 is offline
Old 08-24-2007, 08:46 PM
offshoredrillin's Avatar
Received 1,295 Likes on 449 Posts
rob, check a local hydraulic place that makes hoses, they will have everything and preesure fit the ends, had them made for my 311 in an emergency and it was about 50 bucks, they should have stainless too.
offshoredrillin is offline
Old 08-25-2007, 07:56 AM
Rob Ive already wasted my time cking with our local hose place, The need the reusable chrome plated brass end like what on the boat or stainless.Remember Iam in Mississippi
Old 08-25-2007, 12:41 PM
Received 1,826 Likes on 911 Posts
I had to replace my hoses on the inside of the transom on my MM steering. None of the hydraulic hose places had the correct fittings. I ended up finding an aeroquip dealer and they made them with some 5000psi hose.
Old 08-25-2007, 01:15 PM
sorry to hear that guys, this is who we have around here http://www.colliflower.com/ and they do a great job.
Quick Reply: Need Power Steering hose fitting thats on the rams
