I need a straight answer.... >
Old 01-24-2008 | 10:42 PM
CAPTAIN CHUCK's Avatar
Question I need a straight answer....
I have just spent the last 2 hours reading threads about ss crossovers and I am right back where I started. Are crossovers better than stock?
The engines are 500hp's with stock everything. Most of the threads I did read were from years ago so I was hoping there may be more current info and/or systems.
If I can get an answer that is backed up with proven data I will be able to make my decision based on that.
Thanks guys.
Chuck
CAPTAIN CHUCK is offline
Old 01-24-2008 | 10:58 PM
Strip Poker 388's Avatar
I wouldnt change it out,
Does it still have the Gill exhaust?
Strip Poker 388 is offline
Old 01-24-2008 | 11:05 PM
The Gils are on it for now but I am looking at Stainless Marine to replace them. Still not 100% positive about the SM but at this point it's all about the benjamins. Some nice CMI headers would be sweet but the cost is just a bit to far out of reach right now.
Thanks Rob
Chuck
Old 01-25-2008 | 12:51 AM
racesdad's Avatar
get the stainless marine. headers crack.
racesdad is offline
Old 01-25-2008 | 04:02 AM
The recirc pump will keep temps more consistent. Also, crossovers can create problems with too much water pressure.
Old 01-25-2008 | 05:01 AM
There are good things about crossovers and bad things. The weight savings and additional very small amount of HP you will gain are the major benefits. Not a "scientific", good reason to do it. Don't do it unless you can't live without the bling factor.
SkiDoc is offline
Old 01-25-2008 | 11:35 AM
The problem I was looking to solve was corrosion build up in the stock cast housings. It seems that I will be trading one problem for another so I guess no crossovers for now.
Thank you gentlemen.
Chuck
Old 01-25-2008 | 12:03 PM
BY U BOY's Avatar
Chuck
I say go with it. With the hot tepms of the lake i think you will like the results. I would not worry too much about the High water pressure(you can add a relief valve)
I put one on mine and like the way it cools(no T-stat) and also how it cleans up the engine. I have not had any problems with water press.Its also one less thing to worry about failing while enjoying your day out. Just my .02
BY U BOY is offline
Old 01-25-2008 | 01:54 PM
Corrosion in the t-stat housings? You can always get a Sierra stainless t-stat housing. Or go closed cooling.
handfulz28 is offline
Old 01-25-2008 | 03:17 PM
Dude! Sweet!'s Avatar
The thing that attracted me to them was the whole "one less thing to fail" arguement.
Dude! Sweet! is offline
