Project 353 - 1420 HP with twin 600 SCI `s >
Old 05-27-2008 | 08:02 AM
Default Project 353 - 1420 HP with twin 600 SCI `s
We had first sea trial with our 353 FasTEch with modified Mercury Racing 600 SCI
An Italian Company developed a Tuning Kit for the 600 SCI
We gained about 110 HP per Engine .
With stock engines an 2 inch IMCO Shorties trimmed to 6 and 32 `lab finished Maximus we saw once 93 MPH at 5250 RPM
most times 91 at 5150 RPM
First test with the same props and the boat hits the rev limiter immediatly, doesn`t matter if the drives are up or down
After Boat is on plane it just takes 5 seconds from 3000 RPM to 5450 RPM - So we ordered now bigger props to see the Triple Digits with almost stock engines
(The kit contains a Smartcraft PCM 555 Computer (Exchange or new) , Pully, Cam and gaskets)
The kit will available in the USA soon
contact Ray at Raylar for Details
www.raylarengine.com
In Europe we will distribute the kit
I will keep you updated on top speed results
Dyno Charts show stock and modified engine
All Guardian and smartcraft functions work like stock
The 600 SCI like the 700 SCI has an electronic controlled boost valve - so for Bravo Applications the torque is limited by the modified ecu up to 3900 RPM to let the Bravo drives live longer. (DRIVE SAVER)
File Type: pdf
File Type: pdf
pokerrunboats is offline
Old 05-27-2008 | 12:50 PM
Canada Jeff's Avatar
Well this makes sence, 600 hp seemed rather reserved for the engine with that supercharger.
Canada Jeff is offline
Old 05-31-2008 | 05:20 AM
Full Force's Avatar
Thats good numbers, so you were running 93 with 711hp?
I have a friend with a 353 with procharged/carbed 509 CI running 97 gps last year, he has Imco boxes and 2" Imco shorties, we figured he was around 700 hp, must be more since it runs 97? that is with labbed 32P 4 blades, not sure on rpm, I think 5100-5200..
Full Force is offline
Old 06-03-2008 | 02:32 AM
The boat was running 93 with stock 600 HP
now we hit the rev limiter with stock props and 711 HP -
new props and gears are on order
Old 06-03-2008 | 04:28 AM
Full Force's Avatar
OK, that sounds about right from what I have seen, we figured my buddys engines make around 700-725 hp to run 97
Old 06-03-2008 | 03:35 PM
Your buddy should try the 5 Blade Maximus props
Old 06-03-2008 | 03:47 PM
Full Force's Avatar
The 5 blad would get him more top end? I figured with the 5 blade he would lose some top end, he has not done much with propping yet, he wants to get the engines dialed in first to the best, then do props. what kind of pitch do ytou think?
Old 06-04-2008 | 12:48 PM
The Formula 353 with twin 600 SCI s comes from Factory with twin lab finished Maximus 15 1/4 diameter 31 pitch
with over 700 HP the boat should be able to turn 34 pitch
if you run 1,50 gears
Old 06-04-2008 | 02:46 PM
Full Force's Avatar
Drives are 1.36 ratio he has 32 pitch now.
Old 06-15-2008 | 11:46 PM
little update
yesterday we tested new props
34 ` 15 1/4 lab finished Maximus
still too small for the HP
Boat is still hitting rev limiter very quick
Now we will change gear ratio to 1.35
No speed numbers from yesterday . GPS antenna has to be replaced
