Speed / Hp ?
Old 02-03-2003 | 01:16 PM
JUSTONCE's Avatar
Default Speed / Hp ?
I can't find the sit that had the speed/ horsepwer/ hull drag coeficient(sp) equation. can anybody shoot me the link
Thanks in advance.
Martin
JUSTONCE is offline
Old 02-03-2003 | 01:21 PM
later's Avatar
go-fast.com
Bam marine
later is offline
Old 02-03-2003 | 01:23 PM
JUSTONCE's Avatar
thanks man.
JUSTONCE is offline
Old 02-03-2003 | 01:29 PM
GLH's Avatar
GLH
http://www.go-fast.com/boat_speed_predictions.htm
GLH is offline
Old 02-03-2003 | 01:42 PM
Clay Washington's Avatar
JUST ONCE,
A simple equation that I believe will get you close is:
New Speed = Old Speed times [ the squareroot of (New HP / Old HP) ]
or
New HP = Old HP times [ (New Speed / Old Speed) squared ]
Some people say that it should say "cubed" instead of "squared" but "squared" and "square root" will get you close.
Do the math!
Clay Washington is offline
Old 02-03-2003 | 01:59 PM
JUSTONCE's Avatar
Clay, thats pretty cool seems close!
JUSTONCE is offline
Old 02-03-2003 | 02:11 PM
HyperBaja's Avatar
Calculating for that new blower
HyperBaja is offline
Old 02-03-2003 | 05:04 PM
Mbam's Avatar
Offshoreonly Advertiser
Could be either something is wrong with the data, or that particular hull needs a different constant. The constants are not fixed in stone, but determined from experience with similar boats.
Picture changing to a Sportmaster or Labbed prop or something else that gives you 5-10 MPH with no change in weight or power, the constant will be different.
The best use of the calculator is to input the known weight, speed and power, then calculate a constant for that hull set up.
Mbam is offline
PicChic
11-21-2007 10:46 AM
patricklhill
04-30-2007 06:20 PM
ajl marine
0
09-12-2005 07:35 AM
TGOR
General Racing Discussion
3
03-29-2005 08:07 PM
two-air
Warlock
3
03-15-2002 07:43 PM
