Fuel pumps???
anyone know if carter marine mech. fuel pumps will provide enough fuel for holley 850 double pumpers, the motors are merc 420's built to 510 hp ..... can't find the gph rating on these anywhere...... Or is there somthing else you might recomend??
Try here. You didn't say whether they were on your blocks or sea water pumps. The levers are different.
http://www.cpperformance.com/product...ystems/077.asp
Got the Carters on my 540's with 1050 Dominators and FP guages on the dash...Pressure never varies from idle to WOT. Except once when something was stuck in the needle and not sealing and at an idle it was down about 1 lb and pulsing with each pump of the diaphragm
. Meantime I'm dumping gas down the back barrels
where might i find these carter hv pumps ??
