Fuel Regulator Return line ? >
Old 08-04-2003 | 01:26 AM
Krumbsnatcher's Avatar
Question Fuel Regulator Return line ?
Has anyone ever ran a fuel return line to the hose where you fill your tank?
I talked to the guys at Aeromotive and they said the best results for fuel return is to put the diverted fuel from the regulator back to where you fill your tank.
I used to divert the fuel through a cooler, now I have a cam driven water pump and that is not an option I want to pursue to handle diverted fuel.
My question is can I drill a hole into this hose and screw in a barbed 6 fitting and then secure the fitting with a polymer JB weld. I know the proper way would be to cut a section out of the hose and weld a tube with the fitting and reinsert that back into the line.
Any thoughts.
Krumbsnatcher is offline
Old 08-04-2003 | 09:13 PM
Elite Marine's Avatar
Look up Moroso or look at Jegs, either one has the actual in line hose fitting you are looking for.
Much eaisier and professional.
Elite Marine is offline
Old 08-04-2003 | 09:20 PM
Default Pantera
This is the kit you were mentioning, my only question is the picture or fuel filler hose the same diameter? I know nothing about the marine standards on where to find out info on the hose numbers.
The moroso kit is 2" diameter, but you are right it is exactly what I was going to have to build.
Thanks.
Old 08-04-2003 | 09:22 PM
Dennis Moore
You can also plumb the fuel return line into the vent hose fitting on the tank.
Old 08-04-2003 | 09:36 PM
Question
Here is a question where do you guys run your fuel return line?
I like the idea of the vent Hose dennis.
I am going to see if I have any more pics that could show the situation a little better.
Old 08-04-2003 | 09:56 PM
rbtnt's Avatar
I run mine to a separate fitting in the tank.
rbtnt is offline
Old 08-04-2003 | 10:09 PM
very few tanks have the ablity to return to the tank unless asked for from the manufactuer the best solotiuon is to tee the fill hose i belive cp performance has the part you are looking for
carreraboat is offline
Old 08-04-2003 | 11:01 PM
Dennis,
My fuel vent is kind of tucked away and not easy accessible so I opted for the kit.
I decided to go with Pantera's suggestion it was less than $40 and the kit directs the fuel 90 degress directly into the tank.
Just bought the Moroso kit from Summit should be here in a couple of days. I also could not resist their stainless braided oil dipstick with billet knob.
I will take some pics and post the results.
Old 08-04-2003 | 11:03 PM
Default I know can you believe it!
Luckily my boat is mostly apart from the helm to the engine so running this line will be no problem I hope.
Thanks for your input.
Old 08-06-2003 | 12:59 AM
Strip Poker 388's Avatar
Krumbsnatcher please post a picture when your finished .i need to do the same thing.
thanks
Strip Poker 388 is offline
Noise Pollution
14
04-17-2008 10:49 PM
Elite Marine
Pantera
6
12-26-2006 01:08 PM
CigDaze
7
08-04-2006 11:55 PM
tssteph
6
05-10-2005 07:04 AM
Krumbsnatcher
13
08-12-2003 05:39 AM
