What are the1995 500HP cam specs >
Old 03-10-2004 | 08:22 AM
klaw's Avatar
Charter Member #139 /Moderator/Platinum Member
Default What are the1995 500HP cam specs
who made it and what was the part number I want to compare it to what my motor guy is recommending
klaw is offline
Old 03-10-2004 | 08:56 AM
It was [email protected] intake duration and [email protected] exhaust duration. It had approx .580 and .590 lift if I recall correctly. I believe it was ground on a 110 degree LSA, but it may have been 112LSA. I do know that they installed them slightly advanced in the HP 500.
It was made by crane but had a Merc #.
TomR is offline
Old 03-10-2004 | 09:42 AM
rmbuilder's Avatar
MarineKinetics
Specs for 500 HP
hyd-roller Crane 284/292 .576/.598
Merc #2409-848906A1
Bob
rmbuilder is offline
Old 03-10-2004 | 09:51 AM
klaw's Avatar
I think this is the guy I had the spec I just wanted to check it
Part Number: 169611
Grind Number: HR-284-2S-10 IG
Engine Ident: 1996-UP CHEVROLET V-8 454 THRU 502 CU.IN.
HYD. ROLLER WITH CAST IRON DISTRIBUTOR
DRIVE GEAR.
Kept the Bullet and the condo and joined the cig 20 restoration club.
klaw is offline
Old 03-10-2004 | 09:52 AM
This is out of the Mercruiser Hi-Performance service manual #3
lobe lift intake .339
.002 exhaust .352
Duration at
.050 Cam lift intake 284*
exhaust 292*
Buns is offline
Old 03-10-2004 | 10:51 AM
rmbuilder's Avatar
MarineKinetics
Here is the timing card for the 169611
http://dab7.cranecams.com/SpecCard/D...1=Display+Card
Bob
Old 03-10-2004 | 02:57 PM
klaw's Avatar
Thanks guys confirms the stuff I had I had just wanted to double check
klaw is offline
Old 03-16-2004 | 10:52 AM
Default Carb or EFI
Are these specs for carb or EFI?
Shah Mat is offline
Old 03-16-2004 | 10:58 AM
klaw's Avatar
carb
klaw is offline
ubet28
1
10-20-2008 04:10 PM
Ken N
1
05-27-2007 04:20 PM
KCHOTBOAT
4
04-29-2004 03:52 PM
Scott
2
03-08-2002 08:10 PM
