Best Oils
Old 02-09-2004 | 11:40 PM
Default Best Oils
I was wondering what type of oils is everyone using in there high performance engines and out drives.
Also is there any advantage on running an aluminum flywheel on a 502HP?
Thanks in advance,
Mike
Active Mike is offline
Old 02-09-2004 | 11:51 PM
Engine oil=Mobil 1 15/50wt synthetic
Drive lube= Merc Hp Gear Lube
Griff is offline
Old 02-10-2004 | 12:11 AM
merlin540
ulx110 20w50 merc in the drives
Old 02-10-2004 | 02:21 PM
38KV's Avatar
Engines - Penzoil 20/50
Drives - Merc hp gear lube
BTW,Why don't we use single grade motor oil,
since we don't use our boats at winter time?
Aluminium flywheels are for dragracing,
when you need that rapid throttle response.
Don't use it on boats unless it is a top fuel dragboat.
38KV is offline
Old 02-10-2004 | 02:38 PM
I have been running Valvoline Racing 40w but thinking about the Mobil 1......in the drives I use Amsoil ....Fred
fred is offline
Old 02-10-2004 | 07:54 PM
Kent Perroux
Tried an Aluminum flywheel on a smallblock pushing an 18'. Had to bring the rev's up to shift into gear. Pulled the engine and put the heavy flywheel back on the next week. You need the centrifugul force to keep the motor from dying when you put it into gear.
Old 02-10-2004 | 09:05 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
I use the Merc 20w50 motor oil and the Merc HP gearlube for drives. Stock 502's.
US1 Fountain is offline
Old 02-10-2004 | 10:40 PM
The outdrive presently has redline shockproof/heavy oil in it.
The engine is running a straight 50w Mobil.
I was debating on changing the engine over to Purple ?
As for the aluminum flywheel that is what I thought. I was seeing if any one tried it.
Mike
Old 02-11-2004 | 08:31 PM
Rotella T 15w40 in the engines and Merc HP lube in the drives
Bajaforce is offline
Old 02-12-2004 | 07:42 AM
we use purple products in everything!
audacity is offline
