I need advice on a new trailer >
Old 04-06-2005 | 05:04 PM
Default I need advice on a new trailer
I definately want triple axil
Who to look at
what type of brakes
electric or hydraulic
what size wheels and tires
This is for a 1990 Sonic 30SS
Oh Yea,,...SALT WATER!!!!!
Pure Energy is offline
Old 04-06-2005 | 05:21 PM
ChrisK's Avatar
Moderator
Default Re: I need advice on a new trailer
Myco triple with electric over hydraulic, tortion axels, drive gaurd, aluminum, and a tool box on the front.
ChrisK is offline
Old 04-06-2005 | 05:22 PM
NJSONIC's Avatar
I have had very good luck and performance from our Mycos. I would say get the aluminum if you trailer and dunk all the time.I have heard pluses and minuses for the electric over hydraulic brakes.So I have had surge type.
I had a twin axle under our 1988 scarab panther. The trailer was rated at 10,000 lbs.. Our last boat 2001 358 had a triple axle rated at 15,000 lbs. When I spoke to Bill Tweede at Myco he said the dual axle was strong enough for our 358 but is said give me a triple axle.I have an other Myco under our new 386. I went with steel all three times because I don't dunk the trailers that often.When I needed parts for the trailers Myco was great to deal with.
Tom
NJSONIC is offline
Old 04-06-2005 | 07:26 PM
'05 Concept SF23
Get the electric over hydraulic disk brakes. They work. Joe Murray
f311fr1 is offline
Old 04-06-2005 | 08:13 PM
Special K III's Avatar
Owens & Sons of St. Pete. Best cat trailer (IMO).
Special K III is offline
Old 04-06-2005 | 09:31 PM
Originally Posted by License To Thrill
Pure why do you think you need a triple axle trailer? Two will do just fine. The center tires don't do anything but scrub off rubber in turns and add weight.
Twice I have lost bearings on the road. Once with a tandam and once with the triple I have now. Nice to know I can continue after tieing up the bad axil.
Old 04-06-2005 | 10:12 PM
timewarp's Avatar
Kodiak Disc Brakes, they aren't cheap but if you get the stainless ones you won't be disapointed. Either Surge or electric over hydraulic, your choice.
timewarp is offline
Old 04-06-2005 | 11:09 PM
Tantrum's Avatar
Good point. I haven't had that happen so it didn't occur to me. I have a triple axle trailer myself but will have a twin axle aluminum trailer built. It will have torsion bar suspension, four wheel disk brakes, electric over hydraulic brakes and LED lights.
I have a strong suspicion there are going to be plenty of LED lights on this trailer
Kendall is the king of the LED's.
Check into the hub set-up I was telling you my new AMT trailer has. The entire hub (bearings and all) can be replaced with one nut.
Tantrum is offline
Old 04-07-2005 | 06:27 AM
offshoredrillin's Avatar
Get a Myco, plain and simple, I got mine and promptly put about 1800 absolutly trouble free miles on it. that peice of mind was WELL worth it!
offshoredrillin is offline
dukenrock
13
02-16-2007 05:20 AM
Gene in NC
08-17-2006 09:56 PM
Ric232
20
01-04-2004 02:48 PM
Rambunctious
5
06-25-2002 09:05 AM
