Water flow & Exhaust Question >
Old 04-11-2005 | 03:44 PM
Dock Holiday's Avatar
Charter Member #34
Default Water flow & Exhaust Question
Just had the 500 EFI's rebuilt, used the original CMI headers and added straight tail pipes dumping the water at the end.
Had the boat on the hose Saturday and noticed that on the starboard engine there was more water coming out the right exhaust then the left exhaust, both before you cranked the engine and while the engine is running.
The engine runs great, the water temp is right where it should be and the water pressure is great.
We put the boat in the water yesterday and I noticed at the docks that about twice as much water was coming out the right as the left at idle in the water.
When I felt of the headers and tail pipes the right was was very cool all over.
The left side was cool everywhere except where the header and tail pipe connect. You could hold your hand on it, but it was warm for about three inches on each side of the coupling.
Anyone have an idea of what is going on here. I called my mechanic and he said that I was noticing this more with the new tailpipes then with the old silent choice system, that all motors did this, that there is never an equal amount of water on both sides.
But the other engine is perfect, equal on both sides and no warm spots on the headers.
Thanks in advance
Doc
Dock Holiday is offline
Old 04-11-2005 | 04:10 PM
Charter Member #34
Default Re: Water flow & Exhaust Question
Well, my mechanic just called and he spoke with Merc and they tell him this is somewhat normal.
I called Randy at CMI and he says he has seen it before and if the headers are not getting hot enough to discolor that I should not worry about it.
Guess I need not worry!
Old 04-11-2005 | 07:02 PM
Do you have the stock T-stat housing????
I know there is a rod with balls on the ends on my 525sc that can be adjusted to balance the flow.
Griff is offline
Old 04-11-2005 | 07:23 PM
tmdog's Avatar
Simple ball valve installed on the water outlet hose will cure the problem. Personally I prefer to dump water equally out of both pipes. That is how I fixed mine.
tmdog is offline
Old 04-11-2005 | 08:02 PM
Charter Member #34
Yes it is the stock housing. They did add new thermostats.
Old 04-11-2005 | 08:26 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
That is a check valve assembly, not a pressure or flow regulator. Besides, it is self centering.
US1 Fountain is offline
Pure Energy
07-27-2004 06:49 PM
Toffen
0
02-02-2003 01:17 PM
Budman
10
10-09-2002 07:47 PM
blown formula
1
03-25-2002 04:04 PM
Waterfoul
18
03-15-2002 07:03 PM
